Old 03-25-2026, 03:39 PM
helmerrock helmerrock is offline
Default Quadrajet inlet experts
I recently acquired a 7029268 for parts and don’t quite understand the inlet configuration. Looks like maybe a screwed in disk with a 7/16 thd? Anyone seen this before?
ID:	666954   Click image for larger version
Old 03-25-2026, 04:52 PM
kyle_blake's Avatar
kyle_blake kyle_blake is offline
ive never seen that. but yah something done to get around stripped threads it looks like?!
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane
The Following User Says Thank You to kyle_blake For This Useful Post:
Old 03-26-2026, 04:55 AM
Kenth's Avatar
Kenth Kenth is offline
Looks like a shadetree fix for a missing correct fuel inlet fitting.
Fuel bowl looks like a SR unit married with the wrong throttle body (Pontiac M4 units never used the APT and PCV fitting in the throttle body).
I guess the glued in threads could be removed, threads for a correct fitting looks fine, and the throttle body will easily be replaced with a correct one.
HTH
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 03-26-2026, 07:35 AM
Half-Inch Stud's Avatar
A good epoxy like marinetex will do well with the desired Inlet.
Old 03-26-2026, 09:49 AM
77 TRASHCAN's Avatar
Cliff is the answer man to this...
Shut it off
Shut it off
Old 03-26-2026, 10:06 AM
scott06 scott06 is offline
Agree that it looks like a work around for the typical fuel inlet stripped threads. Im assuming someone put a pipe thread on the smaller inner diameter, actually not a bad move if SOL.
Get the inlet thread repaired with a timesert, pretty typical issue that a lot of good carb guys can fix.
Old 03-27-2026, 09:06 PM
Pontiac Performance Author
Post a pix of the inlet fitting
