Old 03-30-2026, 04:14 PM
1968junkerjim 1968junkerjim is offline
Default 068 hydraulic roller camshaft
Looking for hyd roller camshaft for a budget build motor 068 or 744 something under .500 lift 716397-3644 if you can help out
Old 03-31-2026, 07:45 AM
RA66GTO's Avatar
RA66GTO RA66GTO is offline
Roller and budget are not really synonymous.
Butler lists both the 068 and 744 available as HR.
We are using, and very happy with, the Voodoo -711 HR. Duration falls between the 068 and 744, but the lift does exceed your 0.500 specification.
1966 GTO Resto-Mod. 2nd owner California car, Factory Air, Power Windows, Kauffman Heads, March Serpentine, Holley Sniper Quadrajet, MSD Dual-Sync, Gearstar 200-4R Level 3, Yank 2400 Stall Converter, Dutchman Axles, HGM Compushift Mini, Heidt's Tall Spindle, UMI Control Arms, Hellwig sway bars, CPP Big Brakes, AR Torque Thrust, Continental ExtremeContact Sport 02
The Following User Says Thank You to RA66GTO For This Useful Post:
Old 03-31-2026, 07:58 AM
67Lemons 67Lemons is offline
Roller cams are not cheap, about $500 for the cam and $700 and up for the lifters plus changing springs, retainers and locks if converting from HFT. You’ll also need a new distributor gear and potential valley pan due to the link bars contacting the pans, about $350 added to the numbers above.
You’re better off with a flat tappet cam in a factory grind, quality lifters, matched springs and doing proper break in.
I have a nitraded Crower 60919 for sale, nitrading the cam is your best bet on any HFT cam along with a great set of lifters such as the Crower cam saver lifters that have a machined area that allows more oil to the cam. It’s the next step up from the 744 so may not work for your build but look for something similar for your build and you’ll have the best chance of success with a flat tappet cam.
1972 GTO
Old 03-31-2026, 12:45 PM
1969GTO's Avatar
1969GTO 1969GTO is offline
contact Paul Spotts, he might be able to help you out.
color me gone
