Old 04-15-2026, 08:25 PM
Pjk68 Pjk68 is offline
Default Seat belt covers
This might be a dumb question but has any replaced their seat belt covers, I have a 67 and I thought the buckle would fit thru the new cover but it doesn't.Any good ideas?
Old 04-16-2026, 08:06 AM
Andre's Avatar
Andre Andre is offline
You have to disassemble the retracting mechanism down to bare bones, remove the belt from the reel and feed it through the cover. That method is alot easier that cutting the stitching at the male end, removing it, pulling the belt through, and restitching.
Old 04-16-2026, 08:12 PM
Thanks Andre, I have a few junk seat belts hanging around I will experiment on them
Old 04-17-2026, 06:24 AM
Jeff Hamlin's Avatar
Thumbs up Option 2
With the belt/retractor out it is possible to warm the plastic cover enough to use a wide blade tool,
gently spreading the slot open just enough to manipulate the the tongue end through the opening.
Try it on an old cover to get the feel. If you don't think it's going to work then
the complete disassembly is suggested.
Its a PITA but can be done.
GO SLOW.
ID:	668320   Click image for larger version
Name:	belt cover.jpg
Old 04-17-2026, 10:42 AM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Hmmm, never knew this was an issue on '66 - '67. I've always been able to angle the tongue through the retractor cover opening on my GM cars.
Old 04-25-2026, 05:12 PM
I ended up taking the retractable unit all apart,it wasn't to bad of a job,
I took apart an old spare one and put it back together to figure out how it worked
The Following User Says Thank You to Pjk68 For This Useful Post:
