Old 05-05-2026, 11:00 PM
Default Wtb 74 TA FB 455 auto/ac 80a alternator bracket...
Old 05-07-2026, 10:58 AM
noticed some i see are flat as a schoolgirl and some are curved for rigidity.
Which is the right type for my application?
Old 05-07-2026, 12:08 PM
Is that an 80 amp alternator? Looks like standard size alternator?
The 80 amp ones I have seen are bigger than normal size alternators. Also usually used an idler pulley on passenger side.
Pic of a 73 bracket: (#6 in front of alternator)
Old 05-07-2026, 04:05 PM
That is just a rando pic from the internets.
I don't know what my TA came with but I have an 80a on there now.
I've seen both types of brackets however and this one is more wobbly than I would like and had to put spacers to line up with the belts.
That curved one looks like a better design.
Old 05-07-2026, 04:32 PM
Held for Ransom's Avatar
Pictured here...
https://forums.maxperformanceinc.com...d.php?t=399948
So long, farewell.
Old 05-07-2026, 04:54 PM
that one looks like the flat one I got...hmmm
Old 05-07-2026, 05:59 PM
Mike's pic has the idler pulley for adjustment.
You would need all of those brackets to make the PS bolt up also. (U shaped bracket at bottom)
Plus the idler pulley stuff on left side of pic.
Old 05-18-2026, 08:58 PM
jerry455 jerry455 is offline
The brackets with the pulley are what is on my 1976 Firebird. The alternator is fixed and the pulley is adjusted to take the tension. 80 amp is different than the others.
Old 05-19-2026, 10:48 AM
I found the other bracket type locally.
Thanks fellas
