Old 05-11-2026, 01:23 PM
grivera's Avatar
grivera grivera is offline
Default Need Installation Tips for the Power Trunk Lock Solenoid Harness
I had the trunk lid on my 69 Lemans replaced and need to install the power trunk lock solenoid harness. I assume others here have done this - any tips on how to feed the wire without it getting stuck in trunk the bracing?
Will Rivera
Old 05-12-2026, 10:40 AM
I've had luck running the wire up from the hinge area with a taped loop at the front. then I run a piece of coathanger wire with a small hook formed on it from the solenoid opening area to snag it.
a rub of the solenoid wire with an oily rag helps it slide better
Old 05-12-2026, 01:46 PM
grivera's Avatar
Great tips - thanks
Will Rivera
