Old 05-12-2026, 04:38 PM
ottofaro ottofaro is offline
Default 69 Rally 2 Trim Ring Measurements
I'm looking for a set of original 69 Rally 2 trim rings. Could someone please provide the key measurements - outer, inner, depth and any other that may be critical to determining if correct OEM.
Thanks,
Jack
Old 05-12-2026, 04:51 PM
I assume you are talking about the trim rings used on the correct 14x6" wheels?
Old 05-12-2026, 07:17 PM
Yes, as originally equiped
Old 05-13-2026, 03:06 PM
I'll take few pics with a tape measure and post them tomorrow.
Old 05-14-2026, 05:21 PM
Here is a trim ring on a survivor GTO, as far as I can tell they are factory original and many of my cars with 14x6" rally's have the identical design rings. I seem to recall there was a change from brushed to polished or vice versa at some point. All mine are the polished variety like this one.
ID:	670089   Click image for larger version
ID:	670090   Click image for larger version
ID:	670091   Click image for larger version
Old 05-14-2026, 05:24 PM
Here is one installed, different car but identical trim ring.
Old 05-15-2026, 09:32 AM
Cammer-6 Cammer-6 is offline
69 14x6 trim rings were same as rallyI and early rallyII
part# 9781480.
they were brushed finish and have 4 retainer clips that grip outside lip of wheel,
unlike those pictured here that grip inside of bead lip.
Keep in mind 69 also had a 7 inch wheel.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 05-15-2026, 12:08 PM
My early 69 (sept 68 build) had the brushed rings but all my current GTO's and a LeMans (all are built later in the year) have the polished rings and all are survivor cars.
The applications for the 7" wheels in 69 are:
Firebird-all models except base engine 1bbl OHC and even with that engine if F series tire option was ordered. (base engine cars had E series tires)
Grand Prix: all models except if equipped with manual steering (Power steering was made standard on the GP on jan 1st 69 IIRC.
Old 05-16-2026, 09:21 AM
Super helpful north. Thanks so much!
Old 05-16-2026, 09:22 AM
Thanks everyone for the help.
Old 05-17-2026, 10:31 AM
Default Believe 69 should have 4 clip style trim rings
Hmm, I didn't notice this at first because I was focused on the measurements but it's my understanding a 69 should have the 4 clip style of trim ring and be polished. My car is a May 69 BTW. Are the measurements any different between the two styles?
