Old 05-29-2026, 05:51 PM
bluebird455 bluebird455 is offline
Default 1970-74 Trans am Engine/Motor mounts
Need recommendations of mounts for street driven 74 Trans am.
see a lot of Metal ones online? are they any better? what about vibrations/noise?
Thanks in advance
Old 06-01-2026, 07:04 PM
unruhjonny's Avatar
My ;
Rubber was chosen for a reason - it is the best material for a street driven vehicle.
anything stiffer will have vibration repercussions - with the worst being a solid mount.
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
Old 06-02-2026, 09:46 AM
78w72 78w72 is offline
Stick with original mounts for the street IMO, if there is more power than stock, make your own "mighty-mount" out of stock mounts... Thats all they do, they grind the "made in taiwan" off stock mounts and install a .25 cent bolt.
I make my own and add a little extra strength, been in a 72 firebird with a 500+hp stroker that runs low 11's, so far they have lasted for 10+ years.
The Following 2 Users Say Thank You to 78w72 For This Useful Post:
