Old 05-31-2026, 10:06 PM
gtorich gtorich is offline
Default can fuel line shrink this much
Odd question, was hooking stuff up today and this fuel line fit last year with no problem............you can see in the pic im quite a ways off to getting the hooked up to the front carb. lol................pretty sure i used fuel injection hose also.
Have a laugh on me
Rich
Name:	Front carb bracket.jpg
Old 05-31-2026, 10:17 PM
SRGN SRGN is online now
Have your girlfriend talk to it seductively and see if it expands. Just kidding, yeah the newer fuel hoses that resist ethanol do some weird stuff, generally single use.
Old 06-01-2026, 04:35 AM
steve25 steve25 is online now
Some FI hose can be a rip off.
There sold more by there rating to handle pressure then dealing with engine temps and the fuel that runs through them.
I always wipe a on a film of synthetic wheel bearing lube on nipples d before I slip a hose one.
They then come apart with far less force and cure words being heard.
Old 06-04-2026, 11:26 PM
Schurkey Schurkey is offline
HOSE on the pressure side of the fuel pump is not a good practice. Sometimes it's unavoidable, but then you use the minimum amount of hose that will allow for engine shake--eight inches, give-or-take.
Metal tubing--double-wall seamless steel is ultra common. Nickle-copper "NiCopp" tube works well. There's hard-plastic tubing used by the OEMs that has good results. But hose? Not if I can help it, and if I must, it's the steel-braid-over-Teflon (PTFE) liner stuff.
