Old 06-04-2026, 04:40 PM
misterp266's Avatar
Default Richmond 5 Speed
Putting linkage on to make a new tunnel fit properly. I’m not sure whether the front rod mounts up or down. Conflicting pics on line. Pic I got with the trans shows lever up but exploded view shows lever down which makes more sense.
Anyone running one?
Pics for example and clarity.
ID:	671324   Click image for larger version
" Darksiders Rule "
Old 06-04-2026, 05:05 PM
MatthewKlein MatthewKlein is offline
Shif the transmission into gear. Spin the input and count revolution on output. If its in the correct geat the revolutions will tell you
Old 06-05-2026, 10:13 AM
400 Lemans's Avatar
400 Lemans 400 Lemans is offline
https://www.shifterdoc.com/4070009_Install.pdf Looks like it goes down.
Old 06-15-2026, 05:13 PM
6T5 Cat's Avatar
6T5 Cat 6T5 Cat is offline
Picture 2 is correct. It goes up. I have pictures of my 65 Cat but I don't remember how to add them to a post...it has been a while.
[SIGPIC][/SIGPIC
The Following User Says Thank You to 6T5 Cat For This Useful Post:
Old 06-16-2026, 02:28 PM
misterp266's Avatar
Thank you. Finally someone who actually has this transmission installed! Are you happy with it?
" Darksiders Rule "
