Old 06-11-2026, 01:16 AM
6262's Avatar
6262 6262 is offline
Default Battery terminal orientation on a '65 Bonneville
Hi! Does anyone know if the negative battery terminal on a '65 Bonneville faces the fender or the engine? In other words, is it on the left or the right when viewed from the front? I’ve seen it both ways; the split seems to be fifty-fifty. Thanks! Nils
Old 06-11-2026, 10:00 AM
pfilean's Avatar
pfilean pfilean is offline
I would think they were always negative nearest to the engine so the negative cable would go right to a Bolton the front of the head to maybe to some bolt on an accessory bracket. The positive would then run along the inner fender. I suppose a 65 might get a group 24 battery and not the group 24F.. The terminals are reversed between those groups.
The Following User Says Thank You to pfilean For This Useful Post:
Old 06-11-2026, 04:02 PM
Jonsie Jonsie is offline
Yes, positive cable next to the fender
The Following User Says Thank You to Jonsie For This Useful Post:
Old 06-11-2026, 09:07 PM
3 Chiefs's Avatar
3 Chiefs 3 Chiefs is offline
My 65 GP has the positive near the fender too. There is a short red wire that goes to the horn relay on the fender behind the battery. I think that is stock. I know that wire would not reach the engine side of the battery.
I never met an old car that I didn't like.
The Following User Says Thank You to 3 Chiefs For This Useful Post:
