Old 06-13-2026, 11:25 AM
hgiv hgiv is offline
Default Water pump leak
Well things were going too smoothly! 428 swap was going well. Filled up with antifreeze today. It started dripping out where the water pump meets the intake. My guess is the gaskets are just dried out. I saw no signs of anything before. I checked all the bolts and everything is tight.
I guess everything is coming off the front so I can fix this. Ugh. Not complicated but a pita. I just got everything on! lol
I’m wondering if I should replace the water pump while I’m in there? I have no reason to believe there is a problem but…
Old 06-13-2026, 11:42 AM
zippy's Avatar
zippy zippy is offline
The round seal? hey are hard. I Silicone both sides, Loosen intake just so it can move a little. If Water Xover is separated form intake, but loosen that. Tighten all the other water pump bolts, then tighten the WP to Intake bolt. Then tighten intake back down
Dan Pesonen
"If it ain't broke, modify somethin till it is"
Old 06-13-2026, 11:51 AM
Now I’m wondering if taking off the intake is easier, or the more appropriate route?
Old 06-13-2026, 03:07 PM
chiphead's Avatar
chiphead chiphead is offline
Pull the intake. It will pull forward using the transfer bolt and seal the donut. The timing cover won't do that. agree on light coat of gray silicone on both sides of donut gasket.
Old 06-13-2026, 03:09 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
I’m wondering if I should replace the water pump while I’m in there? I have no reason to believe there is a problem but…[/QUOTE]
Reseal and run it. I'd take the pump off by itself
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 06-13-2026, 06:46 PM
grivera's Avatar
grivera grivera is offline
Agreed- if it isn’t leaking at timing cover/intake seal, why disturb that
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
Old 06-16-2026, 02:50 PM
Default Updated
Well I pulled the intake. Water crossover was super gooked. Not surprised it was Leaking. I cleaned it up, as well as the intake and heads. Will put it all back together tomorrow and try again!
ID:	671891   Click image for larger version
The Following User Says Thank You to hgiv For This Useful Post:
Old 06-17-2026, 08:54 AM
chuckies76ta's Avatar
New donut rubber gasket, use right stuff each side of that gasket.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick.
Best so far 9.95@135 mph. 1.39 60 ft.
468 with KRE D-ports, Doug headers, 3" Exhaust
950 Quickfuel.
The Following User Says Thank You to chuckies76ta For This Useful Post:
Old 06-17-2026, 10:51 AM
grivera's Avatar
JBP sells a thicker o-ring that makes sealing easier
Will Rivera
