Old 06-15-2026, 10:57 PM
SD421's Avatar
SD421 SD421 is offline
Default Opinions On This “Line”
Im reassembling my motor and noticed this.(see pics)
Any ideas on this straight line on the snout of the crank?
Ive never see this before.
I sent this pic to my machinist. His response is that it’s not a crack Cracks dont create a straight line.
ID:	671819   Click image for larger version
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 06-15-2026, 11:05 PM
tempest1964's Avatar
Looks like a stress crack to me. Maybe your machinist doesn’t want to admit he missed it? I’m not sure you can drill a small hole at the end of the crack to create a termination point, kinda like glass. Not sure. Hope others will chime in.
1964 Tempest Custom
421 SD clone
KRE 74cc heads
KRE 230°/236° hydraulic roller cam
Rebuilt 3.23 rear end
The Following User Says Thank You to tempest1964 For This Useful Post:
Old 06-15-2026, 11:29 PM
TXSTARFIRE TXSTARFIRE is online now
Can you feel it? Could it just be a stain from the keyway slot in the crankshaft timing chain gear?
Old 06-16-2026, 12:20 AM
SRGN SRGN is offline
I'd drill a tiny hole in the end of the crack as suggested above, and run it. Unless you are using it for direct drive on a procharger, it will likely look the same if you take it apart again in 10 years.
Old 06-16-2026, 12:30 AM
VCho455's Avatar
VCho455 VCho455 is offline
To me it's hard to tell from the photos. It could be a mark from when the key slot was machined or a crack. Personally I'd get some crack checking dye penatrant and it should reveal more.
Old 06-16-2026, 02:17 AM
dataway's Avatar
dataway dataway is offline
Is that on the drive side of the keyway or the back side? I should know by looking, but I don't
Old 06-16-2026, 02:43 AM
Joe's Garage Joe's Garage is offline
Default Back side
Since the crank rotates clockwise, it's the back side of the keyway.
The Following User Says Thank You to Joe's Garage For This Useful Post:
Old 06-16-2026, 06:18 AM
Half-Inch Stud's Avatar
Timing gear had a burr to write that line. No worries.
The Following 4 Users Say Thank You to Half-Inch Stud For This Useful Post:
Old 06-16-2026, 09:31 AM
HWYSTR455's Avatar
Pull the key out, shine some light in there and take a pic at like a 45 degree angle toward that area.
Looking at it from the top with those pics it's hard to tell if it's a crack or just a groove/step.
The key looks a little beat up on that side too, almost like the balancer was loose and hammered it.
Old 06-20-2026, 10:49 AM
Green Elephant Green Elephant is offline
I would check it with dye penetrant as suggested below. Or tape off the bearing area to protect it and see if a shop can mag particle test it while it’s assembled. If I was going to hammer on the motor I would want the peace of mind.
Old 06-20-2026, 05:50 PM
HWYSTR455's Avatar
I like the dye suggestion, makes total sense....
Old 07-10-2026, 03:17 PM
SD421's Avatar
Sorry, for the late response. Took the crank back to my machinist and he looked at it. Not a crack but a groove from the harmonic balancer.
1966 GTO
KRE Tri-Power
The Following 2 Users Say Thank You to SD421 For This Useful Post:
