Old 06-18-2026, 09:20 AM
JAL71TA JAL71TA is offline
Default Rally Wheel decoding help
I have 5 matching 14x6 rally 2 wheels that I am most likely going to clean up a bit and look to sell. The markings are: inner rim, 14x6 1...2 ...G ...Made in USA JK. M9
The markings near the valve stem read: 2...7 JL. So I have three questions for the experts here,
why are the letter codes different and which one is correct to list when selling?
What car(s) do these fit?
What would be a reasonable price to list these for?
They all have some surface rust, nothing bent or misshapen,lug holes look true.
Thanks in advance!
Old 06-18-2026, 02:27 PM
Mr. G Mr. G is offline
List them using the JL code at the valve stem. The wheels are early 1970 14x6 rally IIs that were shown to come on 1970 Tempest. M9 indicates they were made in 1969. Lug spread should be 5 on 4 and 3/4. and will fit firebirds and tempest , Lemans and GTO as well as GPs from 1969 and after.
Old 06-18-2026, 02:31 PM
Thanks!
Old 06-18-2026, 02:36 PM
unruhjonny's Avatar
As I have understood it, the inner markings are for the inner assembly - before the wheel was assembled with the desired offset;
The marking at the valve stem indicates the final product, which include manufacturer and line, date, and wheel code.
John made a really good page for this HERE
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
Old 06-18-2026, 05:19 PM
Thanks that makes sense, seems like I have July 2nd for 70 GTO etc wheels. In my previous message I reversed the 2 and 7. I would like to see these sell to someone looking for a matched set for their car.
As soon as I clean them up a bit I may post them for sale.
Thanks again.
Old 06-18-2026, 05:40 PM
Production of JL coded rally II's was from very early July '69 till 11/25/69.
Only in the Tempest line, the JL coded 14x6 was used. It was originally installed on drum brake as well as disc brake builds w "two piece" rotors same as used with previous 14x6 JA coded Rally II's.
Typically, nice condition date matching sets of JL's dated from early Sept of '69 through 11/25/69 bring the most, as typ sought out for serious restorations on early '70 Judges.
On 11/25/70, the first 14x6 JT Rally II's were stamped. Depending on assembly plant, it took a while for the one piece rotors & JT's to be phased in.
The JT 14x6 Rally II continued to be stamped up into early July of '70, then a few more runs were made before the Fall of '70 UAW Strike.
Old 06-18-2026, 07:46 PM
Ok thanks, I guess I had it wrong on the GTO vs Tempest....appreciate the info. When i do attempt to sell them I want to be as accurate as I can .
Old 06-19-2026, 03:54 AM
Kenth's Avatar
Kenth Kenth is offline
Tempest, LeMans and GTO are A-body´s, either could have used the JL wheels.
Std on The Judge though.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 06-19-2026, 08:19 AM
Thanks for the reply.
Old 06-24-2026, 10:18 AM
GoGoat GoGoat is offline
Default Received virus from post #4
I clicked on "HERE" in post #4 and got pop up virus'. I had Wallace racing in my favorites but today this happened. Luckily my son in law is in cyber security and fixed my probelm. Beware on what you click on.
66 GTO Conv Tripower 4 spd stock
67 GTO HDTP 400 auto stock
70 Judge 400 RAIII 4 sd stock original
69 Firebird 468 auto 28 option
49 F1 302 aod
