Old 06-24-2026, 07:10 AM
hpp's Avatar
hpp hpp is offline
Default 400 block question
I got this 70’ 400 block from a friend who passed away he ran super stock does this look like it has been O ringed or sleeved?
ID:	672360   Click image for larger version
Old 06-24-2026, 07:27 AM
johnta1 johnta1 is online now
Those round circles look like o-ring grooves?
Are they a groove or just marks left from a gasket?
What is the engine code for the block?
Old 06-24-2026, 07:34 AM
hpp's Avatar
hpp hpp is offline
They are raised grooves from what I can tell the block has been machined at some point.
Old 06-24-2026, 08:39 AM
If they are raised it probably is sleeved?
Usually they are milled flush with block.
Old 06-24-2026, 08:42 AM
Looking at the underneath pic, it could be sleeves. They will not fill the bore all the way to the end usually.
Is there a step at the bottom?
Old 06-24-2026, 09:35 AM
Nacs Fab's Avatar
Nacs Fab Nacs Fab is offline
Looks like my O-Rings. My block had also been sleeved in one cylinder and that stepped space on the bottom looks same. Make sure you remove the o-rings and save them when you hot tank the block.
Name:	Top End DS.jpg
69 Firebird - Angry Bird
455 with 84mm Torqstorm
The Following User Says Thank You to Nacs Fab For This Useful Post:
Old 06-24-2026, 10:30 AM
performerrpm's Avatar
performerrpm performerrpm is offline
Send a message via AIM to performerrpm
does that one have 4 bolt caps or 2? looks like its a ceapshoot with that casting 400.
Old 06-24-2026, 10:59 AM
hpp's Avatar
hpp hpp is offline
Looks like they do have step at the bottom and the o rings are raised slightly. It is a 4 bolt 400 block
Old 06-24-2026, 11:00 AM
hpp's Avatar
hpp hpp is offline
What are your opinions on a sleeved block for street use?
Old 06-24-2026, 11:02 AM
I have no problem with them. If done right.
Old 06-24-2026, 12:02 PM
Nacs Fab's Avatar
Fill the block to below freeze plugs if you are concerned. I run mine and its keeping at 180 temp when my fans and water pump are working!
The Following 2 Users Say Thank You to Nacs Fab For This Useful Post:
