Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 06-27-2026, 08:23 AM
performerrpm's Avatar
performerrpm performerrpm is offline
Send a message via AIM to performerrpm
Default 68 wt 400 complet and running
i traded for a nice running 67 lemans last week. it had a 400 put in place of the 326. i assumed someone had just thrown in a later 400 when i was working the trade out which was fine because i was looking to put my 67 400/467 motor in its place. i dont have any info on it since it was put in by the owner before last. what i did find was that it is a 68 400 wt block with #16 heads, that my guess is original to the block. i havent checked the date code but the intake maybe original to the motor too. it has the 68 timing cover on it that i would imagine is also original. runs great, 60# oil pressure hot just off idle, hot idle 25-30 # in gear. runs 180°. no noises, doesnt smoke. the only thing i found wrong is a leaky vc gasket.
i plan to leave it in as long as possible so it can be heard running. i dont need this motor living on an engine stand lol.
$1,500.00 complete carb to pan minus the brackets. timing cover and water pump included. it is drop in ready.
located in locust grove, ok
The Following User Says Thank You to performerrpm For This Useful Post:
Old 06-27-2026, 08:28 AM
can take or send pictures of anything needed that i can get to in the car
ID:	672511   Click image for larger version
Old 06-28-2026, 10:24 PM
edit to say, this motor has a new qft 600 vac secondaries carb that would go with it
Old 06-28-2026, 10:30 PM
Region Warrior's Avatar
An original WT dont want?
Stop hurting me!
Old 06-29-2026, 01:05 AM
Stop hurting me!
lol...the good thing is, if it dont sell itll end up in the garage on a stand, stripped down n painted and waiting for the next pontiac to show up.
Old 06-29-2026, 08:32 AM
pending
