Old Today, 01:21 PM
PYCSXVNT12 PYCSXVNT12 is offline
Default '70 Bonneville - Removing IP with Dash Board left in place.
Can I remove my instrument panel in my .70 Bonneville while leaving the Dash Board in place?
I've looked at it and removed the 3 screws at the top of the IP above the speedometer, but nothing seemed to move.
I've read you can pull it out, remove the speedometer cable, and the wiring plug...but I can't see where the screws are?
Best Regards, PYCSNVNT12
Old Today, 06:00 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Can't say for sure on full size cars but anything 1969 and newer in the Pontiac A body series cars, you have to first remove the dash pad and gauges as and assembly then very carefully place your dash-pad face down on top of the workbench; first covered with some carpet and/or padding.
Then remove the screws that hold the gauge cluster into the backside of the pad. Most likely Big cars would be similar in 1970.
Peter Serio
Owner, Precision Pontiac
