Old 07-21-2026, 08:02 PM
67GTO4SPD's Avatar
67GTO4SPD 67GTO4SPD is offline
Default Correct 4 speed shifter with console?
My ‘67 GTO came with an aftermarket Hurst shifter and it does not work with a console. I want to add the console back to my car since it had one from the factory. I’ve seen several ‘67 GTO shifters listed on eBay, but I want to be sure I get the correct one. Will other years fit or is ‘67 a unique year? I always assumed ‘64 - ‘67 would work since they used the same console, but I see some listed as ‘65 - ‘66 and some as ‘67 only.
‘67 GTO - stock(ish) appearing 406, #16 heads (ported by Steve Magnotti to flow 265/208), 703 Lunati VooDoo cam, 800 cfm Buick Q jet, ported Edelbrock Performer Intake, Ram Air 2.5 exhaust manifolds, M20, 3.55 Safe-T-Track
(Formerly 67GTO4SPEED)
Old 07-21-2026, 09:01 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
I don’t have the exact part number of the ‘67 handle, but they have this mild bend with the HURST name.
The Following User Says Thank You to 60sstuff For This Useful Post:
Old Yesterday, 12:58 AM
bdk1976 bdk1976 is offline
65/66 have the base of the handle integrated into the shifter mechanism. The 67 handle slides in and is removable without taking the whole thing apart.
The Following User Says Thank You to bdk1976 For This Useful Post:
Old Yesterday, 07:07 AM
67GTO4SPD's Avatar
So I assume the ‘65 - ‘66 one would work on my car? I don’t care so much about originality - I just want it to work. The console opening is so small that seems that the shifter has to have a pretty tight pattern.
Were the shifters for console and non-console cars different?
Old Yesterday, 10:03 AM
george kujanski's Avatar
An associated question i hope... are the '67 consoles, (3 speed and 4 speed) the same? I have a '67 3 speed console (Lemans Sprint) and '67 4 speed GTO.
Thanx in advance, George
The Following User Says Thank You to george kujanski For This Useful Post:
Old Yesterday, 02:10 PM
Same '67 console for LeMans or GTO
Old Yesterday, 02:25 PM
'65-66 Pontiac A-body had different shaped shifter sticks for Console or Non Console applications.
Production '67 Pontiac A-body Hurst shifter went to the "stab in" bayonet style stick. This year was separated into sticks for either bucket seat or bench seat application.
The chrome shifter stick used for that "67 bench seat Pontiac A-bodies was the same shape from '67-70. For '71 & 72 Pontiac A-bodies , buckets seat & bench seat used the same shifter stick (4555).
Old Yesterday, 07:43 PM
Goatboyjohnny Goatboyjohnny is offline
Call Dennis, he should be able to set you up with exactly what you need, really nice guy and dies great work.
The Following User Says Thank You to Goatboyjohnny For This Useful Post:
