Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 3
1
2
3
Showing results 1 to 25 of 70
Search took
0.04
seconds.
Search:
Posts Made By:
J.C.you
Forum:
Pontiac - Street
05-03-2024, 09:12 AM
8
Tie Down Classic Car
374
Posted By
J.C.you
Tire straps
Tire straps
Forum:
Pontiac - Race
04-19-2024, 12:23 AM
61
Summit racing drops speedmaster products
4,267
Posted By
J.C.you
Summit’s entire product line is probably 70%...
Summit’s entire product line is probably 70% china, I believe they’re just protecting theirselves against legal action
Forum:
Pontiac - Race
04-14-2024, 06:41 PM
26
porting went wrong
1,895
Posted By
J.C.you
Grab another 96 head, can’t be that expensive
Forum:
Pontiac - Race
04-04-2024, 08:55 PM
16
What say yee…
1,768
Posted By
J.C.you
Make some progress. Went with the modified...
Make some progress. Went with the modified original glass scoop. Wanted the sd scoop but was just too wide where it needed to be in relation to the carb to look decent.
Forum:
THE LOBBY
03-10-2024, 11:44 PM
25
MRE meals?
1,508
Posted By
J.C.you
Ha! Thanks for replies, very informative. Been...
Ha! Thanks for replies, very informative. Been thinking to stock up on a year supply. Never know what the future brings.
Forum:
Pontiac - Street
01-23-2024, 05:51 PM
19
Handy chart
1,393
Posted By
J.C.you
Many years ago I remember flowing my old...
Many years ago I remember flowing my old superchiefs at 10” local shop and they went 510@.900 hehe, then at Meauxs 430@.900. I mentioned it to Meaux and he said very possible on a small bench, so I...
Forum:
Pontiac - Street
01-19-2024, 09:41 PM
18
Switching from Pertronix back to breaker points. Question
2,048
Posted By
J.C.you
Did you happen to change the coil? Pertronix uses...
Did you happen to change the coil? Pertronix uses a specific coil
Forum:
Pontiac - Street
12-16-2023, 02:53 PM
19
Is it posible to replace this fuel line?
2,674
Posted By
J.C.you
I have done aluminum 1/2” line with a fuel filter...
I have done aluminum 1/2” line with a fuel filter splice along the inner frame rail several times with the body attached to the frame. If your combo is other than stock your butt meter will thank you...
Forum:
Pontiac - Street
11-23-2023, 05:20 PM
22
Solid lifter oil restriction
1,170
Posted By
J.C.you
One can tap and restrict the feed hole in...
One can tap and restrict the feed hole in aluminum roller rockers ensuring everything up to that point has full oil access.
Forum:
Pontiac - Street
11-20-2023, 02:02 PM
62
What air cleaner ???
4,694
Posted By
J.C.you
Spliced a couple together with drop base, made...
Spliced a couple together with drop base, made this
Forum:
Pontiac - Street
10-26-2023, 11:55 AM
176
Who Has The Rarest Street Driven Pontiac?
12,091
Posted By
J.C.you
It’s world’s fastest too😁
Forum:
Pontiac - Street
09-23-2023, 09:28 PM
21
Performer rpm apps?
1,094
Posted By
J.C.you
[QUOTE=PAUL K;6456364]Check the carb gasket for...
[QUOTE=PAUL K;6456364]Check the carb gasket for overhang in the plenum. Remove the bump on the inner passenger side front carburetor bolt boss.
When that manifold first came out I carefully...
Forum:
66-67 GTO Tempest & LeMans TECH
07-02-2023, 03:18 PM
28
Red fender liners?
1,648
Posted By
J.C.you
Hey Greg, nightwatch blue, black interior, 3x2,...
Hey Greg, nightwatch blue, black interior, 3x2, 4sp,, original drive train. I know it’s corny, but a barnfind disassembled many years ago. One owner widow car.
Forum:
Performance Parts For Sale/Wanted
06-25-2023, 08:07 PM
10
wanted narrowed rally 2 wheels
832
Posted By
J.C.you
Alternative bigs and littles….Use set of super...
Alternative bigs and littles….Use set of super lights, paint or powder coat, use adapters, then poverty caps
Forum:
Pontiac - Race
03-11-2023, 06:13 PM
36
Hemi 7s
3,992
Posted By
J.C.you
Hemi 7s
Saw on FB, someone here combo?
Forum:
Pontiac - Race
12-22-2022, 02:34 PM
25
Port volumes
2,319
Posted By
J.C.you
Off topic but…. If someone didn’t have anything...
Off topic but….
If someone didn’t have anything else to do, I believe one could graft two iron heads together, raise the ports and make a killer iron cheater head.
Borrowed this pic SS sd head
Forum:
Pontiac - Street
12-02-2022, 10:40 PM
55
“Why Pontiac Started Strong and Faded into Obscurity”
5,125
Posted By
J.C.you
My experience the weak part of cast rods was the...
My experience the weak part of cast rods was the big ends would be egged on about 1/2 the cores we tore down. Which would have led to bearing failure then perhaps bolts breaking. Never broke a cast...
Forum:
Pontiac - Race
06-25-2022, 08:14 PM
28
Cylinder head dimples/golf balls Q
4,448
Posted By
J.C.you
Don’t go into ports often, but when I do, dimples...
Don’t go into ports often, but when I do, dimples are there….
Forum:
Pontiac - Race
06-22-2022, 12:45 PM
28
4,448
Posted By
J.C.you
I believe Meaux did some back to back dyno tests...
I believe Meaux did some back to back dyno tests and the dimpled ports made more power on the application he was testing.
There should be more golf ball experts in cylinder head r&d
Forum:
Pontiac - Street
06-04-2022, 12:35 PM
121
using small/very small valve heads on 455 to optimize very low rpm torque
10,480
Posted By
J.C.you
I think the op wants to use bathtub old style...
I think the op wants to use bathtub old style heads and mirror image custom dish pistons.
My prediction will it be a pinger without at least some Singh grooves to quench area furthest from initial...
Forum:
Pontiac - Race
02-08-2022, 09:44 AM
24
Rich Guido at Sick Week
3,974
Posted By
J.C.you
Bet he's one of one running the roads in a 65...
Bet he's one of one running the roads in a 65 goat with snow tires mounted up,hehe...
Forum:
Pontiac - Street
12-07-2021, 08:52 AM
38
Turned down 428 crankshaft
5,385
Posted By
J.C.you
Ohio crank may cut the crank for you....and...
Ohio crank may cut the crank for you....and possibly do some spacers
Forum:
Pontiac - Street
04-18-2020, 10:32 AM
111
Hopefully a Nice Stout Motor - Your thoughts?
17,624
Posted By
J.C.you
What brand lifters Tom. He restrict lifter bores?...
Another thing to the OP, get a shaft recommended for tight lash for street. Less beating on on those lifters.
Forum:
Pontiac - Street
04-12-2020, 12:57 PM
28
4500 Dominator On the Street?
3,383
Posted By
J.C.you
Every 500 plus cube roller motor I've run liked...
Every 500 plus cube roller motor I've run liked the 1150 at the track over 1050,. Tried 1250s too and seem like the 1150 was the sweet spot. Just my junk, mind u.
Forum:
Pontiac - Race
04-01-2020, 11:38 AM
68
Will we race??
6,978
Posted By
J.C.you
Nice, emano, emano.... As earnest p. Worrell...
Nice, emano, emano.... As earnest p. Worrell sez...
Page 1 of 3
1
2
3
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
05:32 PM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
