Checked that looks like stock mount couldn’t go any lower because of linkage.
A little can make a lot of difference, the one poly trans mount I had moved the front down an inch or more.
Just figured I'd throw it out there, so you're not overlooking a potential cause. .
Absolutely appreciate all the help.
Seems like everything I run into usually someone’s already been there. |
I had the same issue with my 66, I was told the frame was probably tweaked, I didn't buy that idea. It turns my new motor mounts were setting the engine too low in the cradle, I found some REALLY old NORS stock mounts, they fixed the problem! I see AMES now sells stock mounts that are supposed to be dead on to the originals, I'd try those before I bought their 1/4 spacers.
I actually made a couple of spacers that worked but ended up changing the mounts gd to go. The mounts were the problem.
Which mounts did you end up using that worked?
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
I used the Ames Torq lok
