Old 09-24-2022, 11:07 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Try and blend the ports back up wider. use a snap gauge to keep the width of the port up higher into the port and up at the top of the port. the repop I had we had to add weld in areas of the divider and the top of the port as there was so much core shift on some of the pairs.
Skip Fix
  #202
Old 09-24-2022, 11:25 PM
Verdoro 68's Avatar
I wasn’t sure how much to take off and how far back to go. Sounds like I could go wider, farther up to the port. Dumb question - is the general idea to keep the port the same width as much as possible as far up the plenum? I want to avoid “hogging” this thing out.
There are a couple port dividers that are pretty close to the gasket, but I didn’t find any places where I’d need to add material. Maybe I got lucky. I’m using a 1233 gasket.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
  #203
Old 09-25-2022, 09:46 AM
Skip Fix's Avatar
I think most good intakes have so taper from a larger port getting smaller at intake/manifold opening
Skip Fix
  #204
Old 09-25-2022, 01:10 PM
Verdoro 68's Avatar
Pics I’m using for reference from Cliff, Jim Hand and SD. These are cast iron, not sure what the casting difference is, but I see a couple of them have the middle of the plenum cut back a lot more than mine.
The third pic looks like what I have going on. In an old post Cliff said not to cut the notch unless you can dyno test. Seems like it either helps a lot or hurts a lot. Jim Hand put the notch in his spacer, so I’ll just leave it out.
Cliff’s intake:
Ken
  #205
Old 09-25-2022, 01:27 PM
Formulajones's Avatar
Cliff’s intake:
Touching on what Cliff said about not cutting the notch unless you can dyno test is exactly what I was eluding to with the spacer deal. Leave the intake alone, use a short 1/2" spacer and cut the notch in that. Easy to swap back and forth at the track or on a dyno, only takes 5 minutes. See if it makes a difference. If it doesn't help, then you didn't permanently modify the intake, remove the spacer and move on to other things.
One other thing I've always done is follow what Jim Hand did, which I don't see in those pictures. Always seemed that Jim wanted the front primaries in the intake to be the same size as the throttle blades of the Q-jet, basically making the divider pretty thick in that area and then quickly thinning down towards the rear barrels. Not shown in those pictures.
So basically the top of the intake opening matched the primaries on the carb, then take that design and blend and open wider inside the intake. The idea was to create a venturi affect on the primaries and better throttle response. That's how I've seen Jim do his intakes. He would do the same with spacers.
https://youtu.be/XqEydRRRwqE
  #206
Old 09-25-2022, 01:33 PM
Here is an iron BBC intake I was working on with a 1" spacer, done in a similar fashion as a Pontiac intake. Can't tell in these pics but I also raised and smoothed the roof at the transitions to help make the turn. It's tricky to get the grinders in there.
The end product I also trimmed the outside of the spacer to mimic the intake and gasket, then painted it blue. Looked like part of the intake at that point.
ID:	599316   Click image for larger version
  #207
Old 09-28-2022, 06:34 PM
Verdoro 68's Avatar
It's a pretty hard turn on the intake I'm working on too. I was wondering about smoothing it out.
Generally, I'm feeling ok about the port clean up work on this intake for my first time doing this. I left everything at 80grit. Seems it's better to leave the finish rougher than smoother, but I'm not sure what the standard is. The pics make it look more uneven than it is for some reason. You can see a couple spots where I caught the grinder on the gasket surface.
There are casting seams in the ports I'm wondering about. They push the port wall very close to, or right on top of, the gasket. I was wondering if it's worth the trouble of leveling them out with some epoxy.
I think I've taken the top end of the manifold about as far as I can with a grinder. If I wanted to cut it back to a straight divider, I'd need to take it to machine shop to be milled out.
ID:	599465   Click image for larger version
ID:	599466   Click image for larger version
Ken
  #208
Old 09-28-2022, 06:39 PM
Verdoro 68's Avatar
Outside of that...I'm working on boring stuff a little out of order from the way I'd normally do it since I'm waiting on the heads. Got the front cover fit and installed. Put the balancer on, put the Tomahawk windage tray on, started clearancing the FlowKooler water pump and divider.
I also picked up a new oil filter housing. It looks like my original had a crack in it that was JB Welded at some point (I probably did it). The oil pressure sender fitting was just about stripped out too and couldn't be tightened all the way. I'm pretty sure one or both was contributing to an oil leak.
ID:	599469   Click image for larger version
ID:	599470   Click image for larger version
ID:	599471   Click image for larger version
ID:	599472   Click image for larger version
Ken
  #209
Old 09-30-2022, 01:41 PM
77 TRASHCAN's Avatar
77 TRASHCAN 77 TRASHCAN is online now
What brand is oil filter housing?
Question for you, others...plenum picture on post 207. Do you just break the edge at the bottoms of the plenum cuts (where the plenum enters the intake runners). Wondering if there is desired width of taking that sharp edge down?
Next thought.. those edges that turn into the runners...would it be good cut that curved area entering the runners, making that turn through a straightened line (of course not leaving a sharp edge, when done) instead of though the bottom of the round machined hole?
Shut it off
Shut it off
  #210
Old 09-30-2022, 01:55 PM
Verdoro 68's Avatar
I ordered it from Butler, but it's an Ames part (N219RH).
https://butlerperformance.com/i-2445...au-n219rh.html
Exact diecast reproduction GM oil filter housing. Exceeds OEM quality. Manufactured with the most modern machine tool technology available. Features oil filter bypass with correct opening rate, which is a must for any rebuild. Bypass eliminates the chance of oil starvation and pressure loss due to filter restriction and/or filter failure. Steel threaded insert for oil filter, ensures oil filter will remain fastened correctly and threads won't wear or strip over time.
Ken
  #211
Old 09-30-2022, 03:32 PM
That's what I do, sort of treating it like the short turn in a cylinder head. It's a bit difficult to get in there and do it by hand because you can only access it from one side, but can be done to a satisfactory level.
  #212
Old 10-03-2022, 06:03 PM
Verdoro 68's Avatar
Not much progress over the weekend. I decided to put the pan on which I usually save until last, but I thought I might help keep the internals clean while I wait for the heads. I used Permatex Ultra Grey on the back corners around the main cap and at the timing cover bends of the pan.
I ended up cutting off the tabs on the BOP pan gasket because they weren't lined up exactly with the slots on the oil pan and causing the seal to sit on the ridge on the main cap unless I pried it into place. I used the support brackets on the corners with longer bolts and torqued everything down to BOP spec. I think it's about as sealed as it's going to be.
The Harland Sharp Diamond Series rollers I ordered a few weeks ago also arrived. They're quite a bit less chunky than the PRWs so they'll probably have an easier time fitting under stock valve covers. I've run rollers before with the 1/4" gasket and it hasn't been an issue.
Comparison pics just because (HS is orange, PRW is blue)
ID:	599901   Click image for larger version
ID:	599905   Click image for larger version
ID:	599906   Click image for larger version
ID:	599907   Click image for larger version
Ken
  #213
Old 10-03-2022, 06:09 PM
Verdoro 68's Avatar
The Harland Sharps come with beefier poly locks the larger roller wheel sticks out further from the body.
ID:	599909   Click image for larger version
ID:	599910   Click image for larger version
Ken
  #214
Old 10-03-2022, 06:39 PM
grandam1979 grandam1979 is offline
I would have used a cork gasket on the rear of the pan myself with that style rear main cap. That main is cut to hold the gasket. Just my 2¢
  #215
Old 10-03-2022, 07:21 PM
HWYSTR455's Avatar
Ah, for some reason I was thinking the PRWs you had were the stainless ones, good thing you got the HSs.
You still might want to check the rocker clearance to cover if you are using OE covers.
  #216
Old 10-03-2022, 07:47 PM
Verdoro 68's Avatar
It is, but the BOP gasket is the same width as the cork seal. Seems to crush and fit the channel well, but you can see that it sits about 1/2 way between the slots in the pan in the pics. Not sure if that's a seal problem or a pan problem, but the instructions say it's ok to remove them if you need to. Thinking about filling it up and angling the stand a bit to see if I have any leaks at the rear while I wait for the heads.
No, I had the cheapie PRWs. Except for the valves, springs and associated hardware, I've used very little of what Kauffmann sent me for the original build plan.
Ken
  #217
Old 10-03-2022, 08:50 PM
I didn’t realize you used a one piece gasket my bad. I have one here I need to look at it better.
  #218
Old 10-06-2022, 11:37 AM
Verdoro 68's Avatar
Filled the block up with oil and tipped it back to test the rear main the pan gasket. It looks sketchy in the pic, but don't worry, it wasn't going anywhere. I was feeling confident so of course it leaked like a sieve! I thought it was the arch on the back of the pan, but that looks to be sealing ok. Looks like the rear corners of the pan gasket are the culprit. Rear main shows no signs of leaking at the moment.
The Ultra Grey I used on the corners did not adhere to the block at all and might be reason why it leaked so bad. I cleaned the block rails pretty well with brake cleaner before installing and it's been sitting for 4 or 5 days now, not sure why it didn't stick. There wasn't a problem using it to stick the crank scraper down. It glued it self to the gasket pretty well though. Back to the drawing board I guess.
ID:	600027   Click image for larger version
ID:	600028   Click image for larger version
ID:	600029   Click image for larger version
Ken
  #219
Old 10-06-2022, 11:42 AM
https://www.permatex.com/products/ga...-maker-7-5-oz/
  #220
Old 10-06-2022, 11:55 AM
Verdoro 68's Avatar
Funny, I was going to pick some of this up for the intake manifold reseal I need to do on my T/A. I hear it's pretty stout. I haven't been impressed with the grey stuff so far, blue is typically my go to.
Ken
