Old 11-14-2023, 12:04 PM
JLBIII JLBIII is offline
Default Distributor gear
I have a Comp roller cam in my engine and a Davis distributor I'd like to install. What distributor gear are people using with a roller cam? Thanks
Old 11-14-2023, 12:41 PM
Seems like a lot of guys like the composite BOP Engineering gear. I have one ready to install. I think that or a bronze gear are the only options out there
Old 11-14-2023, 12:55 PM
jhein's Avatar
jhein jhein is offline
Both Butler and my engine builder said to use the BOP poly gear with my CC roller cam and DUI HEI..
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
Old 11-14-2023, 01:28 PM
Verdoro 68's Avatar
BOP poly gear here. So far so good.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around)
Old 11-14-2023, 02:01 PM
This is my go-to:
https://www.holley.com/products/igni...rs/parts/85631
If you want, after @1000 miles, you can switch to the BOP, it's less than half the price of the BOP, and the first gear is usually somewhat sacrificial. If you don't switch, or regardless of which gear you use, check it after @1000 miles.
Old 11-14-2023, 02:02 PM
You need to know the dizzy shaft diameter too. (.491/.500)
Old 11-14-2023, 02:19 PM
mysticmissle's Avatar
Hei should be 491 msd is 500 make sure you dress the cam gear and you should have no problems with either brass or composite
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
The Following User Says Thank You to mysticmissle For This Useful Post:
Old 11-14-2023, 02:23 PM
I've dressed the last few I did, it helps, but there always seems to be some 'mating' wear.
I use a honing stone.
Best advice, check it to be sure.
Old 11-14-2023, 04:06 PM
Steve C. Steve C. is offline
Articles from MSD will point out the effort that goes into a ring-and-pinion installation. Yet many don't think twice about the distributor gear/cam gear relationship unless performance starts to suffer. How the dist gear and cam gear mesh is just as important as the quality of the metals involved. MSD states the excessive clearance between the gear teeth shouldn't be fixed by shoving the distributor farther into the hole; this screws up the proper wear pattern.
Old information here:
The Following 3 Users Say Thank You to Steve C. For This Useful Post:
Old 11-14-2023, 05:43 PM
Dragncar Dragncar is offline
This is my go-to:
Its only less than half the price if the BOP gear is for a RAV/SD455
.500 and .491 gears are 150 $
I ran a BOP gear for over a decade, did not dress a thing ( but cam was used) and it looks new.
I reused it for the last engine. The Comp Cams core had a gear that looked very smooth. Almost polished. So I ran it as is.
Tom s has had great luck with running a stock iron gear for 5 minutes then switching to BOP/bronze
The Following 2 Users Say Thank You to Dragncar For This Useful Post:
Old 11-14-2023, 06:29 PM
tom s tom s is offline
Running the stock gear is something I learned form Joe Sherman(RIP).We just ran it for breakin on the Dyno or run stand.We always ran the drilled dist gallery plug.Tom
Old 11-14-2023, 09:22 PM
JLMounce JLMounce is offline
BOP poly gear, no issues, about 20k miles on it.
-Jason
1969 Pontiac Firebird
Old 11-15-2023, 08:45 AM
As a note, a quick way to check (generally) gear clearance is to grab the rotor and rock it back & forth.
Another way to check is with a timing light, blip the throttle, and see how much timing goes past initial on decell (RPM).
Most don't realize there's a problem until they actually pull the dizzy and check.
Running a standard gear for a short period of time is a great idea, it works, and have done that before. Even after dressing the cam gear.
Old 11-15-2023, 12:41 PM
chuckies76ta's Avatar
Good read. https://www.onallcylinders.com/2022/...r-gear-to-use/
The Following User Says Thank You to chuckies76ta For This Useful Post:
Old 11-15-2023, 02:54 PM
Originally Posted by chuckies76ta View Post
Some good information. Always nice to read up. I saw in that article that composite gears may have an issue with high volume/pressure pumps.
So I gave BOP Engineering a call(answered right away, which is HUGE these days), I told him I was gonna be running a Luhn Performance oil pump; he said no problem. He said quite a few guys are running the BOP composite gears with flat tappet cams just for the extra durability.
He also said that high pressure pumps are much harder on everything than hi flow
The Following 2 Users Say Thank You to Joe-Touring For This Useful Post:
Old 11-17-2023, 07:36 PM
Tim Corcoran's Avatar
Tim Corcoran Tim Corcoran is online now
I have the BOP gear on my solid roller engine been in there for years never dressed the cam gear it still looks like new. I also have one on my hyd roller car no cam dressing put it in and forget it. This has been my experience.
Tim Corcoran
The Following User Says Thank You to Tim Corcoran For This Useful Post:
