Old 06-03-2020, 06:34 PM
Rob in NH's Avatar
Rob in NH Rob in NH is offline
Default shock choice
What shock would be good for a stock suspension on a 69 firebird ?
Old 06-06-2020, 07:59 AM
chrisp chrisp is offline
A simple gas charged shock will be fine.
Old 06-06-2020, 04:07 PM
Verdoro 68's Avatar
KYB or Bilstein if you want to get kind of fancy.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
Old 06-06-2020, 05:28 PM
Rob in NH's Avatar
I got the KYB shocks
Old 06-06-2020, 09:18 PM
Rob in NH's Avatar
they came in late this afternoon so I installed them, was surprised to find out it raised my ride height an inch.
vertigto's Avatar
vertigto vertigto is offline
Heard some good things about Varishock.
Old 07-07-2020, 12:11 PM
69f bird's Avatar
69f bird 69f bird is offline
I switched from KYBs to Bilsteins in my '69 Firebird convertible...made a world of difference in ride and handling
All of my cars are Hybrids...they burn gas and rubber!
'73 Ventura, Spotts 462 roller
10.785 @ 122.79, 1.507 60 ft
2850 lbs. plus driver, 3150 race weight
'69 Firebird Convertible, Spotts 455 with long branches
12.561 @ 107.62, best on old 455
4290 race weight
'72 Formula 455 HO
numbers matching auto, work in progress!
Old 07-07-2020, 01:18 PM
JLMounce JLMounce is offline
I run the Varishock SS in my 69 bird and I love them. I don't have anywhere near the stock suspension though.
The SS would still be a pretty decent shock for even a stock suspension car like the OP has. However it's drawback is the fact that the front shocks must be installed on top of the control arm. They can not be mounted through the bottom like a typical factory replacement shock. That means dropping the lower control arm, removing the spring, then putting it back together.
I don't know if I would go to that amount of trouble on a stock suspension car. If I was changing springs, I absolutely would recommend this route if it's in the person's budget.
I had Gabriel VST's for a while when my suspension was just comprised of hotchkis springs front and rear. I actually thought they were decent, especially for the price point. Had decent ride and damping characteristics.
-Jason
1969 Pontiac Firebird
Old 07-07-2020, 07:23 PM
ZeGermanHam's Avatar
Shocks are just dampers and do not have any influence on static ride height. Springs are what determine ride height.
1998 BMW 328is (track rat)
Old 07-07-2020, 07:34 PM
Rob in NH's Avatar
Thats what I thought too. When I got done installing the front shocks I thought it looked different, seamed to look taller so I measured the rear quarters before I installed the rears and it did raise it an inch. I never thought it would do that either but it did.
Old 07-07-2020, 07:37 PM
It's literally impossible for a shock to alter the static ride height. Did a coil spring become misaligned in the pocket? Did you drive the car after you put it back down on the ground?
Old 07-07-2020, 08:14 PM
PontiacJim1959 PontiacJim1959 is offline
Last edited by Stuart; 07-08-2020 at 10:24 AM. Reason: Removed a bunch of unnecessary and argumentative posts.
Old 07-07-2020, 09:29 PM
indymanjoe's Avatar
As Chrisp said. Stock works just fine. I have NAPA Gold gas replacements and have No issues with body roll or bouncing tire wear etc..
Old 07-08-2020, 08:59 AM
RocktimusPryme's Avatar
The decision may have already been made, but the Bilstein is a good mid priced choice.
I originally used a stock replacement type Monroe shock just to have something new. Then maybe a year later put on the better Bilstein shocks. Noticeable difference.
Old 07-08-2020, 10:26 AM
Stuart's Avatar
Stuart Stuart is offline
Was there any change after the car was moved around and driven a bit? The suspension may have simply needed to settle after the car had been jacked up.
Old 07-08-2020, 10:55 AM
Rob in NH's Avatar
I went out to the garage last nite and took a measurement and it is still over 26 inches on both sides, before it was at 25.
Old 07-08-2020, 10:58 AM
Have you actually driven the car, though?
Old 07-08-2020, 11:01 AM
Rob in NH's Avatar
Yes i have.
Old 07-08-2020, 11:05 AM
Sirrotica's Avatar
One way to be sure would be to disconnect the shocks at the bottom and set it back down with them disconnected, bounce the car several times and remeasure it. I've replaced hundreds of gas shocks/struts and never seen any of them lift a car perceptible to the eye.
There are different length shocks that will fit cars that they weren't designed for, and have the same attachments on the ends. Is there any chance the shocks are incorrect, and too long bottoming out, and holding the car up? Seems that the ride would be destroyed if that were the case though.............
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 07-08-2020, 12:18 PM
Rob in NH's Avatar
Shocks arent bottomed out, it rides much better than it did with the old shocks. But if it makes everyone happy and even though my measurements were correct i'll agree with everyone that it didn't raise the car.
