AGR Steering Box Quetion
Anyone running a AGR steering box in their car? I'm thinking of running one of these:
http://www.summitracing.com/parts/ag...c/model/lemans I was also wondering if I could retain my original PS pump. Any input/help would be greatly appreciated -John
1970 Lemans 350/ TH350 ProTouring Madness |
I am on my second in my truck. Quality control not good it needs replacing now.
Ever consider the el-cheapo Jeep Grand Cherokee box swap? It's a 12.7 steering with the correct stops and its bolt in for under $100 bucks. Ive got it on my 67' GTO and its awesome.
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies - Build Thread http://forums.maxperformanceinc.com/...615847&page=23 |
The second one is on there now, doesn't leak, but still has an uncomfortable feel at the top, wanders some. I will probably send the one to a rebuilder, there's several out there that do good work. I suggest that over pulling a boneyard box, can get any ratio you want and no modifications needed. I have an AGR in the driver, got it years ago, never had a problem with it. Go figure. .
I bought an AGR pump and they changed my torsion bar in my box after I had Lee do the 12:1 gears. The steering was too light for my taste.
You may be money ahead to just send your factory box out. At least you know it will be correct for your car and also have the correct stops too. I know both Lee and AGR can do those rebuilds and be sure to specify the torsion bar you want. |
On the AGR power steering box & pump.
I ran a setup in my 70 LeMans. It leaked like a BP oil derrick. Decided to go back to a stock setup with the 3 turn to turn ratio (NAPA has them, but you will need a core). Same with the power steering.
Cherokee grand easy and its a saginaw box.
Grand Cherokee box is the way to go. All you need are inserts for the Cherokee box so you can use your stock lines and a new rag joint. One of the best bangs for the buck I've done.
Ken '68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '95 Comp T/A #6 M6 - bone stock (pics) |
I just picked up a Jeep Grand Cherokee box from Pick-n-Pull for $42, $36 plus $6 core charge. The hose adapter kit from Lee is $20. Better hurry Mr. Lee told me he is retiring and trying to sell the business.
Do you have contacts for Mr. Lee please.
Joe |
Lee's
http://lee-powersteering.com/
I did this conversion on my 70 lemans, was great, had to go manual steering now with the turbocharger. Still saving that set up, you never know. |
what year of steering box would work out of the Grand Cherokee to fit a 67
For my 69 GTO, I bought a faster ratio (2.5) box from Year One and it's been great.
Send your original box to Chip at http://www.powersteering.com/
Tell him what you want it to do...........
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
Just a modified stock ps box for GTOs, could have been IROC, but it definitely wasn't AGR.
http://www.highperformancepontiac.co...o_convertible/ |
Go to PSC in Texas, great stuff http://www.pscmotorsports.com/
Yup. get yourself one of these. I put one in my 72 Lemans, night and day difference. They make fittings so that you can use your existing SAE hoses. Bolts right in, I believe I uses a rag joint for a 1980 Camaro to get to bolt up to the existing steering wheel shaft. I wouldn't pay $400 for no steering box unless it was rack and pinion. :-) 1996 to 1998 Grand Cherokee Jeep steering box.
"Everyone is entitled to be stupid sometimes, but you're abusing that privilege" www.musclecarsgalore.com www.nikivee.com [www.reverbnation.com/nikivee 1967 Pontiac GTO 1967 Pontiac Grand Prix 1972 Pontiac Lemans Sport Convertible 2015 Dodge Challenger ScatPack 392, 6 speed 2017 Ford Explorer AWD |
