Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 9
1
2
3
Last
Showing results 1 to 25 of 219
Search took
0.24
seconds.
Search:
Posts Made By:
chiphead
Forum:
Pontiac - Street
07-07-2026, 05:24 PM
24
WIX oil filters
936
Posted By
chiphead
Baldwin B39 for me. I bet they shrunk that...
Baldwin B39 for me.
I bet they shrunk that WIX filter to save cost and fit into tight engine bays. I'd still use it if I had to. Heck, look how small a filter for a LS is. Even the 5.7 Hemi...
Forum:
Pontiac - Street
06-26-2026, 10:21 AM
51
Silly stock 400 question
1,613
Posted By
chiphead
With 98CC heads, I come up with 8:1 compression. ...
What is the base timing and total timing? 16* base and 34-36 by 2500 should add some pep. What octane do you use? Try 87, it burns faster so...
Forum:
Pontiac - Street
06-25-2026, 05:55 PM
51
1,613
Posted By
chiphead
I'm pretty sure the Gross and Net testing were...
I'm pretty sure the Gross and Net testing were both done on an engine dyno.
SAE standards J1349 and J2723 describe the Net test methods. The difference is the Net test procedure required the...
Forum:
Pontiac - Street
06-18-2026, 03:53 PM
20
New Dyno numbers on 1970 trans am engine
928
Posted By
chiphead
Very nice! What is the compression and...
Very nice!
What is the compression and head flow of the new combination?
Forum:
Pontiac - Street
06-16-2026, 10:04 AM
12
Centrifugal advance question
600
Posted By
chiphead
The self-learning ECUs can fine-tune the fueling...
The self-learning ECUs can fine-tune the fueling but not the ignition timing. The user is expected to enter a baseline timing map and some other open-loop parameters. Then the ECU takes that and...
Forum:
Pontiac - Street
06-10-2026, 04:46 PM
19
69 400 w/mechanical fuel pump goes from 5 psi to zero psi after 20 minutes
574
Posted By
chiphead
Is this a liquid-filled underhood gauge? Those...
Is this a liquid-filled underhood gauge? Those are not accurate at all when they get hot. The air bubble expands with heat and presses on the bourdon tube, which then reads lower than actual...
Forum:
Pontiac - Street
06-09-2026, 12:30 PM
13
428 Pistons help
416
Posted By
chiphead
You order pistons AFTER the block has been...
You order pistons AFTER the block has been checked out.
1: You need the shop to tell you the rough overbore you'll need, The final hone to size is done AFTER pistons are in-hand and measured. ...
Forum:
Pontiac - Street
06-01-2026, 11:06 AM
7
Mechanical Fuel pump
286
Posted By
chiphead
Just bought one, that's the new 550 HP version. ...
Just bought one, that's the new 550 HP version. I run it with 6AN line back to a stock type pickup. I had to install a deadhead regulator set to 5.5 PSI, as it was occasionally blowing through the...
Forum:
Pontiac - Street
05-31-2026, 12:16 AM
19
Carb question Holley and a radical cam
866
Posted By
chiphead
If you've got some experience, it's possible to...
If you've got some experience, it's possible to estimate the idle vacuum for a particular combo. It comes down to static compression, engine size, intake tract design and camshaft specs.
A 400 at...
Forum:
Pontiac - Street
05-31-2026, 12:02 AM
19
866
Posted By
chiphead
Power valve lore is one of those things that...
Power valve lore is one of those things that drive me nuts. The power valve can be open at idle and it won't affect anything. Yeah, I said it.
The fuel metering for idle and transition slot...
Forum:
Pontiac - Street
05-29-2026, 01:19 PM
31
Head opinion
1,118
Posted By
chiphead
I bought a set of NOS hylift-johnson HFT lifters...
I bought a set of NOS hylift-johnson HFT lifters from ebay for about 90 bucks. I did have to clean the hardened shipping grease out. Otherwise they've been fine for about 1500 miles.
Whatever...
Forum:
Pontiac - Street
05-27-2026, 01:35 PM
31
Head opinion
1,118
Posted By
chiphead
Aftermarket rods are worth the money for the...
Aftermarket rods are worth the money for the reliability they provide.
I also ran a XE274 in a 8.8:1 400. Idle quality was choppy, had noisy valvetrain with the fast ramps. Needs a lot of...
Forum:
Pontiac - Street
05-26-2026, 01:16 PM
31
Head opinion
1,118
Posted By
chiphead
I run a Summit 2802 in a 400 with 62 heads. Its...
I run a Summit 2802 in a 400 with 62 heads. Its a beast. If the 2801 made 385 HP, I must be cracking 400. Idles about 900 RPM making 14" of vacuum. It does want at least a 2500 stall converter...
Forum:
Pontiac - Street
05-18-2026, 11:48 PM
13
RPM intake and drop base aircleaners?
581
Posted By
chiphead
Wow, the stubstack. Haven't heard that in many...
Wow, the stubstack. Haven't heard that in many years. I'm sure it would have some influence, as this combo seems to be very sensitive to aircleaner/airfilter shape.
To be clear in my earlier...
Forum:
Pontiac - Street
05-18-2026, 11:05 AM
13
581
Posted By
chiphead
Update.... Got the Allstar domed lid and curved...
Update.... Got the Allstar domed lid and curved bottom to fit with a 4" air filter. 1/4" open spacer below 4150 double pumper.
WOT AFR is now 12.1-12.5. With the 3.5" filter and sharp flat...
Forum:
Pontiac - Street
05-13-2026, 11:20 AM
10
TH400 Trans go kit
446
Posted By
chiphead
I don't know how much HP you're making, but...
I don't know how much HP you're making, but Jakeshoe had some thoughts about the TG kit and high HP. He recommended doing the internal dual-feed instead of the TG dual feed plate over 600HP. He...
Forum:
Pontiac - Street
05-11-2026, 03:59 PM
10
TH400 Trans go kit
446
Posted By
chiphead
The Pro kit is the most comprehensive street or...
The Pro kit is the most comprehensive street or strip kit. It retains automatic shifting and dual-feeds the direct clutch using a multi layer separator plate that routes fluid to both sides of the...
Forum:
Pontiac - Street
04-29-2026, 02:17 PM
24
What ATF should I use
833
Posted By
chiphead
I'm running the real J20C from the local JD...
I'm running the real J20C from the local JD dealership. Even that stuff is cheaper than a case of Dex 3 from the auto parts store. I'm running it as an experiment, as I was planning on...
Forum:
Pontiac - Street
04-22-2026, 12:48 PM
78
new 400 build making Pinto numbers on dyno
4,385
Posted By
chiphead
Yup, its HP level and durability, they go hand in...
Yup, its HP level and durability, they go hand in hand when using stock replacement type parts. A 9:1 400 will make decent power, and have a wide enough tuning window to find a tuning mistake...
Forum:
Pontiac - Street
04-22-2026, 10:52 AM
78
4,385
Posted By
chiphead
If I had another $1500 to throw at it, I'd be...
If I had another $1500 to throw at it, I'd be changing those pistons and rods first. The shortblock is the heart of the whole project. The heads can be replaced later. The engine could be run...
Forum:
Pontiac - Street
04-17-2026, 12:28 PM
8
Fuel regulator placement?
343
Posted By
chiphead
The online reviews said the regulator brackets...
The online reviews said the regulator brackets hit the electric choke on holley carbs.
So I fabricated my own bracket. It mounts to the rear bolt of the thermostat housing. I used the same...
Forum:
Pontiac - Street
04-14-2026, 03:58 PM
78
4,385
Posted By
chiphead
This. Not trying to upset the OP, but this whole...
This. Not trying to upset the OP, but this whole build sounds like a DGAF special. Somebody who doesn't know better would run this engine until he got tired of it. It's like a 2.8L V6, it'll run...
Forum:
Pontiac - Street
04-14-2026, 10:57 AM
78
4,385
Posted By
chiphead
Yeah that's pig rich. That mixture, low air flow...
Yeah that's pig rich. That mixture, low air flow and low compression will yield inaccurate dyno numbers. As more experienced members said, the dyno cell setup looks suspect.
I'd go so far as to...
Forum:
Pontiac - Street
04-13-2026, 12:39 PM
24
833
Posted By
chiphead
I use 4 quarts dex 3 for color and additives, the...
I use 4 quarts dex 3 for color and additives, the rest Hy-Gard John Deere transmission fluid because its cheap. The turbo racer guys swear by it on YB. There is a standard viscosity and low...
Forum:
Pontiac - Street
04-13-2026, 10:01 AM
78
4,385
Posted By
chiphead
A 400 with 96 heads, .065 head gasket, typical...
A 400 with 96 heads, .065 head gasket, typical 6cc pistons .010 down in the hole is going to be about 7.94 compression. That's with good TRW forgings. Please tell me they didn't use the cast...
Page 1 of 9
1
2
3
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
01:41 PM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
