Showing results 1 to 23 of 23
Search took 0.01 seconds.
Search: Posts Made By: 1969GiPper
Forum: 68-69 GTO Tempest & LeMans TECH 01-19-2024, 06:06 PM
Posted By 1969GiPper
1969-72 G-body (Grand Prix, Monte Carlo, cutlass...
1969-72 G-body (Grand Prix, Monte Carlo, cutlass supreme) should also fit.
Forum: Pontiac - Street 07-05-2023, 05:24 PM
I just had my THM400 rebuilt by a transmission...
I just had my THM400 rebuilt by a transmission engineer that works at the GM Tech Ctr in Warren, MI. He recommended that I use Valvoline Max Life Full Synthetic ATF. He said that Type F is...
Forum: 69-77 Grand Prix TECH 06-07-2023, 09:16 AM
If you unplug the tan wire and turn the ignition...
If you unplug the tan wire and turn the ignition key to ON the fuel gage should go to beyond full. Then if you ground the tan wire going to the taillight loom the gage should go to beyond empty. If...
Forum: THE LOBBY 01-21-2023, 08:45 PM
Did it come with a 12 volt air compressor and a...
Did it come with a 12 volt air compressor and a can of tire puncture sealant?
Forum: Pontiac - Street 12-16-2022, 11:09 AM
Out of curiosity I weighed my GM L88 six lug...
Out of curiosity I weighed my GM L88 six lug THM400 converter and it was about 38 pounds. Probably about half full of fluid.
Forum: Pontiac - Street 11-09-2022, 12:47 AM
Just curious is this engine a 400 Pontiac or a...
Just curious is this engine a 400 Pontiac or a 403 Oldsmobile?
Forum: THE LOBBY 11-02-2022, 08:42 PM
What about the heated rear window defogger grid...
What about the heated rear window defogger grid on the 69 Grand Prix?
Forum: THE LOBBY 04-28-2022, 09:15 AM
My ex mother-in-law would attack without...
My ex mother-in-law would attack without provocation too.
Forum: THE LOBBY 02-14-2022, 02:23 PM
I retired from the GM Tech Center in 2009 at age...
I retired from the GM Tech Center in 2009 at age 56. They wanted to reduce salaried headcount and offered a special retirement package. When I walked out on my last day in September I had my...
Forum: THE LOBBY 12-10-2021, 08:58 PM
So sorry for your loss.
Forum: THE LOBBY 03-10-2021, 01:20 PM
When I was at GM we had an old saying: “We never...
When I was at GM we had an old saying: “We never made one of anything and we never made two alike”.
Forum: 73-77 A-body TECH 03-07-2021, 09:12 PM
[QUOTE=Flashflood;6231748]Trying to get the drive...
[QUOTE=Flashflood;6231748]Trying to get the drive shaft removed from my 77 lemans any thoughts besides the back bolts
Sent from my SM-S111DL using Tapatalk[/QUOTE
Are you using a hoist or is...
Forum: 93-02 General Tech/Discussion 09-07-2020, 09:01 AM
I agree that there is probably a broken wire or...
I agree that there is probably a broken wire or more inside the black flexible conduit located between the driver’s hinge pillar and door.
Forum: 66-67 GTO Tempest & LeMans TECH 05-13-2020, 10:26 AM
I could be wrong but wasn’t the AFB carb used in...
I could be wrong but wasn’t the AFB carb used in 1966 Pontiacs and the “first” usage of the Quadrajet on a Pontiac not until 1967? If that’s correct then having a quadrajet on a 1966 GTO would not...
Forum: 61-66 Big Pontiac TECH 02-25-2020, 10:16 AM
Roto-Hydramatic or Hydramatic?
Forum: Pontiac - Street 02-04-2020, 10:06 AM
Just a thought. Are you sure the tick is coming...
Just a thought. Are you sure the tick is coming from a lifter? Could it be an exhaust manifold gasket leaking which can have a tick type sound that lasts only a few seconds?
Forum: THE LOBBY 01-06-2020, 02:06 PM
I only feed my 3 year old golden retriever what...
I only feed my 3 year old golden retriever what my veterinarian recommends, and that is Science Diet Perfect Weight - Adult.
Forum: Electrical Tech 11-25-2019, 10:35 AM
On older vehicles it’s not uncommon for a wire in...
On older vehicles it’s not uncommon for a wire in the harness to break inside the rubber conduit between the hinge pillar and the door. Over the years the wires in the conduit are being bent back...
Forum: Suspension TECH 03-17-2019, 08:25 AM
Brake shoes on correctly? Primary shoe towards...
Brake shoes on correctly? Primary shoe towards the front of the vehicle and secondary towards the rear?
Forum: 70-72 GTO Tempest & LeMans TECH 12-28-2013, 08:46 PM
If you're swapping out a radio or had a repair to...
If you're swapping out a radio or had a repair to the existing radio done, the last step of the installation process is to "trim" the antenna. This is done regardless of whether you have a mast or a...
Forum: THE LOBBY 12-08-2013, 12:48 PM
Maybe I can help you. I live in a suburb outside...
Maybe I can help you. I live in a suburb outside of Detroit (okay, stop laughing) and there is a guy that lives not far from me that has one or two Darts (67, 68 or 69 vintage 2-doors). When the...
Forum: THE LOBBY 12-02-2013, 11:13 AM
I have one of those old fashion silver aluminum...
I have one of those old fashion silver aluminum trees. No strings of lights to mess with and no pine needles all over the place. Just plug in the spot light with the color wheel (red, green, blue,...
Forum: Heating & Cooling TECH 12-01-2013, 09:01 PM
I bought my 69 GP back in 1973 when R12 was less...
I bought my 69 GP back in 1973 when R12 was less than a dollar a can (14oz). The label on the compressor says that the system holds 4 pounds. That's 64 oz. Over the years cans of R12 got smaller...
