Showing results 1 to 21 of 21
Search took 0.01 seconds.
Search: Posts Made By: cmoc-bob
Forum: 70-72 GTO Tempest & LeMans TECH 07-15-2026, 01:18 PM
Posted By cmoc-bob
So people know - besides the compressor rebuild,...
So people know - besides the compressor rebuild, they clean Evan's, rebuild STV and POA's.
Always had good work from them.
Back in the day, Corvette Fever had some very detailed articles on...
Forum: 70-72 GTO Tempest & LeMans TECH 07-14-2026, 04:59 PM
Posted By cmoc-bob
Classic Auto Air - in FL
Forum: The Body Shop TECH 06-21-2026, 03:01 PM
Posted By cmoc-bob
Mike, On YouTube "Foothill Paint and...
Mike,
On YouTube "Foothill Paint and Fabrication" did several shows on fixing a kinked/warped repro hood.
He's doing a '67 GTO Project.
Really good.....several shows.
Bob
Forum: 69-71 Judges only TECH 05-28-2026, 01:32 PM
Posted By cmoc-bob
Judge OO convertible went for $386K
Forum: Suspension TECH 04-26-2026, 10:29 AM
Posted By cmoc-bob
On YouTube, Foothill Paint and Fabrication did a...
On YouTube, Foothill Paint and Fabrication did a multi-part story on frame squaring. They are doing a '67 and it was quite a bit off - looking
like it was mfg'd that way too.
Forum: Members Helping Members 04-26-2026, 10:26 AM
Posted By cmoc-bob
Mine stopped too, been awhile.
Forum: Suspension TECH 12-07-2025, 10:27 AM
Posted By cmoc-bob
"Hub Plates" mount the wheel assembly using the...
"Hub Plates" mount the wheel assembly using the lug nuts holes.
Coats and Hunter sell these, I would recommend the Hunter Road Force balancer.
I remember a Coats balancer training that noted...
Forum: Pontiac - Street 11-07-2025, 11:29 PM
Posted By cmoc-bob
1970 GTO VOE - mfg up in Canada called MotiveAir Exhaust
These semi-look like Waldrons Mufflers from 2005-2010'ish.
Anyone ever talk to them - not seeing prices or much info via web searches.
I do know from calls with Waldron many, many years ago...
Forum: Pontiac - Street 10-11-2025, 09:36 AM
Posted By cmoc-bob
Shady is an understatement - this is outright...
Shady is an understatement - this is outright fraud to me.
Forum: Pontiac - Street 10-10-2025, 06:47 PM
Posted By cmoc-bob
Direct injection engines suffered from "LSPI" -...
Direct injection engines suffered from "LSPI" - Low Speed Pre-Ignition.
Caused by the additive packages used, this has been fix.
Which is why it's critical to use the correct spec oil in...
Forum: Pontiac - Street 10-09-2025, 03:21 PM
Posted By cmoc-bob
Remember, GM EOS was only used to break in a...
Remember, GM EOS was only used to break in a motor back in the day, not to supplement your base oil.
Mixing anything into your base oil is playing Russian Roulette with the additive package...
Forum: Pontiac - Street 10-03-2025, 06:23 PM
Posted By cmoc-bob
Yeah, mostly (to me) private equity buyouts and...
Yeah, mostly (to me) private equity buyouts and mergers usually means Wall Street is going to cash in and destroy the companies in their fold.
NY Times did a good story a year or two ago about Red...
Forum: Pontiac - Street 10-03-2025, 05:45 PM
Posted By cmoc-bob
First Brands Bankruptcy - some of our car parts included
First Brands (Private Equity firm) bought a bunch of car part suppliers.....
Fram, Anco, Raybestoes, Cardone to name a few.
Forum: 67-69 Firebird TECH 06-26-2025, 06:57 PM
Posted By cmoc-bob
Just finished one on a '59 Corvette. It was a lot...
Just finished one on a '59 Corvette. It was a lot of work.
Directions have pictures, but they are hard to "reference", parts are not labeled and the mfg doesn't seem to know what is what.
I did...
Forum: The Body Shop TECH 06-24-2025, 06:06 PM
Posted By cmoc-bob
MasterCraft is an agricultural paint, watch this...
MasterCraft is an agricultural paint, watch this and see what you think. Guy that does these does some very good testing.........
YouTube "Repair Geek"
Forum: Heating & Cooling TECH 06-09-2025, 11:25 AM
Posted By cmoc-bob
I don't think deep vacuum works with desicant. ...
They typically get "baked" to remove moisture.
Like the separate beads on a baking sheet in your oven. Desicant beads are used in air compressor...
Forum: Heating & Cooling TECH 05-27-2025, 02:38 PM
Posted By cmoc-bob
Build video from Century Auto Air for the A6 -...
Build video from Century Auto Air for the A6 - explains installation of both the OE seal and the double lip seal.
https://www.youtube.com/watch?v=0c7QXLNqgBU
Forum: Heating & Cooling TECH 05-26-2025, 09:25 PM
Posted By cmoc-bob
I'm sure the 'engineer" could look up a part...
I'm sure the 'engineer" could look up a part number as well as us.
And yes, the R4 seal fits. Not any way a "new and improved" A6 designed shaft seal.
Just a seal that fits that they...
Forum: Heating & Cooling TECH 05-26-2025, 09:08 PM
Posted By cmoc-bob
Classic Auto Air does excellent work, send it...
Classic Auto Air does excellent work, send it down to them for a rebuild. And live with the fact the shaft seals will leak.
Mostly from sitting and non-use. About the best I got from an A6...
Forum: Heating & Cooling TECH 05-26-2025, 08:39 PM
Posted By cmoc-bob
Pretty sure it's not an "updated seal", they...
Pretty sure it's not an "updated seal", they dis-continued the original seal.
I have to check, but I believe this is the R4 shaft seal.
Classic Auto Air can fill you in on shaft seals with A6...
Forum: Pontiac - Race 01-05-2025, 05:30 PM
Posted By cmoc-bob
Gale Banks Engineering Differental Cover video
Posted a link in the street section, very good video explaining fluid, covers, aftermarket covers -- and some real world and very involved testing.
https://www.youtube.com/watch?v=vdtmDl5EDJ8
