Old 10-02-2012, 11:29 AM
tom s tom s is offline
here are some pics if they help anyone.Tom
ID:	299188   Click image for larger version
ID:	299189   Click image for larger version
ID:	299190   Click image for larger version
ID:	299191   Click image for larger version
  #382
Old 10-02-2012, 11:31 AM
few more
ID:	299193   Click image for larger version
ID:	299194   Click image for larger version
ID:	299195   Click image for larger version
  #383
Old 10-02-2012, 11:32 AM
last two
ID:	299197   Click image for larger version
  #384
Old 10-02-2012, 02:46 PM
ahnuld's Avatar
ahnuld ahnuld is offline
tom your car must be loud with those muffers, does your exhaust hit going over the diff below the panhard bar, i got 3 inch on mine and we tried that but it kept hitting mainly when the car was in the air, wheels off the ground, nice pics by the way. Dan
63 Lemans ride along and drag race.
https://www.youtube.com/watch?v=XMJHMPx7KAQ Gear Jamming
https://www.youtube.com/watch?v=mw7KPRASomg At the track
  #385
Old 10-02-2012, 06:08 PM
xlrate's Avatar
xlrate xlrate is offline
Gary K the 67 Ram Air A-body exhaust fits like a glove with the V8 x-member no clearance issues with starter, mounts frame or steering. You would think these were made for this car.
I did buy the short turn pipes from Ram Air restoration on recommendation.
- Todd
Originally Posted by GaryK View Post
Xlrate - Did the driver's side Ram Air manifold clear the steering or did you have to modify the steering to get it to fit?
Nice work on the exhaust!
Gary
  #386
Old 10-02-2012, 07:51 PM
the car is quieter than with 2 chamber flomasters!I LOVE them,had them on the RA V bird also.Can actually listen to the radio now.Nothing hits anywhere on the car.The guy that built the exhaust system did a GREAT job,all stainless from the headers back.Tom
  #387
Old 10-02-2012, 09:09 PM
GaryK's Avatar
GaryK GaryK is offline
- Todd
Thanks Todd, I had a feeling they would fit. I ran one on my 4 cyl and had my friend custom bend a 2.5" exhaust. HE said the bend off the manifold was tough. I talked to R.A.R.E in Norwalk and he said they make a 2.5 inch pipe for the Tempest. They were not in the catalog when I ordered it and the order taker didn't tell me about them either. Sounds like these short turn pipes were sure worth it!
Gary
  #388
Old 10-03-2012, 06:21 AM
gavin gavin is offline
I have found the drawing of the spacer/adapter for the rope shaft to post 63 cranks. When you give the drawing to your machinist make sure he marks the pcd of the two bolt circles. The other thing for higgen slake is to check the .190 depth as the flex plate you are using may be thinner than the 336 plate. Another thing is the flex plate may have a dimple on it. I used a drill bit to make a matching recess. The way to proceed is to lay the flex plate on to the adapter plate to make the flex plate holes. I marked one side of the hole only as that will give the centres. On the 2.100" circle use dividers to space the six holes.The flex plate holes are drilled to .500". The drive shaft holes must be drilled to the unf tapping size of 8.5mm or equivalent. bolt the flex plate and adapter onto the crank. Carefuly drill the crank using the 8.5mm holes as a guide. The stock hole depth is 1" I went 1.25" and used 1/2" longer bolts. Remove the adapter plate and drill plate holes out to 3/8" and bolt it back on.You now can use the plate as a tapping guide. Use a taper tap first and then use a bottoming tap to finish. When you finish the tap may be just breaking though to the inside but it dosn't matter. Who ever does this next please post some photos as I didn't take any when I did it. don't forget to balance your flex plate to the late flex plate balance.
Name:	Compressed Image - Gavin.jpg
ID:	299284   Click image for larger version
  #389
Old 10-03-2012, 10:53 AM
sdbob sdbob is offline
THanks guys for all the info. I cut my front floors many yrs ago to tie the frames together and never finished em. I almost finished the 4 link then parked the project. Now I started to plan a Satchell link like boodleoof(spl). I felt for cruising that this would offer some advantages over the other link type suspensions-esp handling. I have many 'irons' going would like to finish this car before I retire. Again thanks for the info to get me back to this 63 Lemans. BOb. C5 those look like my 'green' snips laying on the ffront floor! I missplace tools then find them.
  #390
Old 10-06-2012, 01:25 PM
R 70 Judge's Avatar
Originally Posted by R 70 Judge View Post
The top section of my tunnel is removable. It has like 5-6 allen head bolts holding it together. I can post pics if you want.
Looks great BTW!
Originally Posted by gtogoat View Post
Please...thanks
Sorry it took so long. I've been busy.
ID:	299537   Click image for larger version
ID:	299538   Click image for larger version
ID:	299539   Click image for larger version
James
1970 Trans Am
  #391
Old 10-06-2012, 02:04 PM
boodlefoof boodlefoof is offline
Well, I haven't had much time recently, but snuck out to the garage for a couple of hours the other night to start cutting the floors (like blueghoast) in anticipation of connecting the frame rails together with some 2x2x.120 tubing.
Name:	rail sectioned.JPG
  #392
Old 10-07-2012, 09:02 PM
blueghoast's Avatar
That'll really put some strength and rejidity to your car.
I welded mine continuiosly on both sides of the tubing.
GT.
  #393
Old 10-17-2012, 10:50 PM
RAM AIR V RAM AIR V is offline
Default 63 WAGON
ITS GETTING CLOSER. I HOPE I GET IT HOME BEFORE THE SNOW FLIES SO I CAN FINISH IT UP. JUST A FEW SMALL THINGS HAVE TO BE DONE....JERRY
ID:	300682   Click image for larger version
ID:	300684   Click image for larger version
  #394
Old 10-18-2012, 09:09 AM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
James,
How close is your car to being complete?
Calvin Hill
Hill Performance
708-250-7420
  #395
Old 10-18-2012, 09:28 AM
Default 1961 Tempest
Here are a couple pictures of our 1961 Tempest. We've had the car for around 5 to 6 years, picked it up as a driver here in the Chicago area. I remember seeing the car at a service station back in the late 90's. It's all complete and original, it has been repainted, not showing any signs of filler in the body.
The plan was to build this car for heads up drag racing, but the car will sit untouched until I'm able to complete the project in a timely manner, I made a decision to invest in new equipment in my shop versus using the resources on another race car.
Calvin Hill
Hill Performance
708-250-7420
ID:	300727   Click image for larger version
  #396
Old 10-18-2012, 11:59 AM
R 70 Judge's Avatar
Originally Posted by 65nss4spdGTO View Post
James,
Calvin Hill
Hill Performance
708-250-7420
Engine will be done in the next couple weeks. It's ready to assemble.
I still need a converter, driveshaft, in date seat belts, finish the headers, exhaust, and I need to have the 3rd member gone through and possibly add a locker in place of the spool for street driving. Other than that its just a bunch of wiring for gauges and ignition and what not.
James
1970 Trans Am
  #397
Old 10-18-2012, 02:11 PM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
So,,,you will be cruising Van Nyes Blvd by the weekend???
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
  #398
Old 10-18-2012, 02:59 PM
R 70 Judge's Avatar
I wish!
James
1970 Trans Am
  #399
Old 11-05-2012, 06:37 PM
Default 63 S/W
WELL ITS HOME. TO LATE FOR THIS YEAR BUT NEXT YEAR FOR THE 50 YEARS FOR SURE. MY ?IS DOS ANYBODY ON THIS FORUM KNOW IF ANYBODY MAKES THE BLOCK OFF PLATES I NEED FOR THE FIREWALL..JERRY
ID:	302459   Click image for larger version
  #400
Old 11-05-2012, 07:12 PM
Jerry,we just made mine from a thin shhet of fiberglass and painted black.Dont think any are repoed.For gods sake you have to have a pair of real carbs laying around somewhere!Tom
