Old 11-14-2011, 04:26 PM
Originally Posted by 242 Motorsports View Post
Any source or forum to document casting codes for small parts, i.e. brake calipers, carb, rotors, etc.?
Anything to help document the originality of the car as a whole, not just build sheet, VIN, motor code type stuff.
What do you want to know on the calipers, the casting numbers? I have a bunch of rear calipers, might be able to glean something from stack of orig rear rotors too. Calipers changed for '81's, if memory serves right.
  #222
Old 11-14-2011, 05:27 PM
242 Motorsports 242 Motorsports is offline
The rear ones are the originals.
Thge front ones are my concern now.
  #223
Old 04-25-2013, 08:19 PM
bankbook's Avatar
bankbook bankbook is offline
Any information on stencils or measurements on the paint scheme?
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
  #224
Old 04-27-2013, 02:28 PM
MNBob MNBob is offline
I finally made up my mind that I wanted a new 4 speed TA in the spring of 1980. Upon visiting several dealerships, I found that all of the 4 speed cars were gone by that time. Undaunted, I searched and found a speculator car that was called a TATA (the seller explained the model to me).
I went and looked at it and knew I had to have it. A deal was struck and I became the second owner of the car at 47 miles. The car was a Van Nuys car and I have all the original documentation (window sticker, build sheet, owner’s manual, etc.).
I drove it for two years in Minnesota winters and then decided that had to end if the car was to survive. Life was also getting in the way with jobs, marriages, and other issues so I basically put it into storage for 25 years. I would drive it in the summers, but never for more than 500 miles.
The car now has 35,000 miles and is in excellent condition with no rust or rot. The AC compressor clutch is gone and so is most of the paint. I put in a new stereo system (Retrosound) last year and just replaced the headliner. I will post some photos the next time I get back to Minnesota.
1979 TATA Extreme TKO .64
Hedman elite; Pypes 2.5; Borla XS; MSD 6A; Edelbrock intake; open scoop; Sniper Q-jet; Powermaster 150; 4 core radiator/Mark VIII fan; RobbMc mini starter; subframe connectors; solid body mounts; fiberglass rear springs; poly sway bar and link bushings; 81 master; D52’s; Blazer disks; 225/60 & 235/60 17's TrueContact's; relays for PW, PDL, lights; keyless entry
  #225
Old 04-29-2013, 10:09 PM
dreamn69 dreamn69 is offline
I have been restoring this TATA for the last four years. Almost done!
Before:
After:
  #226
Old 04-29-2013, 10:21 PM
bankbook's Avatar
WOW! Great Job so far!!
Look into the hit mans website for a fix for the leaning seats.
Before:
After:
DOC'S TA
Both 4 speeds!
  #227
Old 04-29-2013, 10:34 PM
bankbook's Avatar
Ok Im in! Here are a few pics of my restoration. I just took it out of storage after 4 years to get it finished.
ID:	321628   Click image for larger version
ID:	321630   Click image for larger version
ID:	321631   Click image for larger version
DOC'S TA
Both 4 speeds!
  #228
Old 04-29-2013, 11:06 PM
Yeah, the lean fix is on the list of finishing touches. Good luck with yours.
  #229
Old 05-05-2013, 09:28 PM
bankbook's Avatar
TACH WIRE HELP
Need to know that the tach wire to dist. is the creme colored one coming out top/right above fuse box that spices into an orange wire with brown connector.
DOC'S TA
Both 4 speeds!
  #230
Old 09-01-2013, 01:02 PM
GTOLou GTOLou is offline
Are the repro door panels for the TATA any good? 500bucks or so - anyone with experience?
  #231
Old 10-05-2014, 08:58 PM
bankbook's Avatar
Finally got some paint on the bird!!!
DOC'S TA
Both 4 speeds!
  #232
Old 10-05-2014, 09:00 PM
bankbook's Avatar
Another
DOC'S TA
Both 4 speeds!
  #233
Old 10-05-2014, 09:02 PM
bankbook's Avatar
Bird nd stripes next.
DOC'S TA
Both 4 speeds!
  #234
Old 10-05-2014, 09:03 PM
68ragtop's Avatar
68ragtop 68ragtop is offline
Looks Great!!
Once you can set that polisher down, the fun begins!
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
  #235
Old 10-06-2014, 08:07 AM
Default FWIW
Those pics sure do bring back a bunch of memories.....good and have to live with.
Make sure you can't see or feel the line at the two tone seperation.
Especially on the hood and fender tops.
The new decal will make minor imperfections look huge.
I think most people let it go and I've seen it on several repaints over the years.
Just something that gets overlooked easy in all the excitement.
BTW Looking good there!!
Clay
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
  #236
Old 10-06-2014, 08:38 PM
bankbook's Avatar
Good advice, smooth as glass.
thanks guys!
DOC'S TA
Both 4 speeds!
  #237
Old 12-18-2014, 04:15 PM
Alvin's Avatar
Alvin Alvin is offline
New TATA project thread here http://forums.maxperformanceinc.com/...d.php?t=766460
  #238
Old 12-19-2014, 11:08 AM
3tas4me's Avatar
3tas4me 3tas4me is offline
I will post up some info on my TATA 4-speed along with some pics. Mine is still factory paint, but has some scratches, chips and door dings from being driven over 50k miles. I have been contemplating repainting it, but it still looks decent, even with all the flaws. Hard to remove that original paint because it is that way only once!
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1996 Trans Am WS6
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
  #239
Old 12-19-2014, 11:16 AM
Alvin's Avatar
"Stuff Happens" when you drive them, so "whatta you gonna do?" I say enjoy them instead of "saving them" for someone else...
Hey, happened to noticed your above post count was...
3tas4me
For T/A 6.6? . Looking forward to pix of your TATA.
  #240
Old 12-19-2014, 11:56 AM
3tas4me's Avatar
I saw that post count too and thought oh boy.........
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1996 Trans Am WS6
