Old 03-16-2015, 03:08 PM
SD421's Avatar
SD421 SD421 is offline
Default Single Stage PPG Concept Paint Results
Hi Guys,
Just wanted to share a pic of painting the jambs yesterday.
PPG Concept DCC Single Stage Montero Red
Don
Name:	Jambs Painted.jpg
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 03-16-2015, 03:14 PM
400 4spd.'s Avatar
Looks nice Don. Must be getting close.
Old 03-16-2015, 03:22 PM
SD421's Avatar
Hi Steve,
yes, its getting there. Couple more weeks and I should be able to drive it.
Don
1966 GTO
KRE Tri-Power
Old 03-16-2015, 04:13 PM
Tempest's Avatar
Tempest Tempest is offline
looks great
are you going to jamb it, assemble it, and then spray the entire car together? This is the method that I think I will be going with.
Old 03-16-2015, 04:40 PM
rohrt rohrt is offline
Are you doing the whole car in single stage?
Old 03-17-2015, 09:05 AM
SD421's Avatar
Originally Posted by Tempest View Post
looks great
Yes
1966 GTO
KRE Tri-Power
Old 03-17-2015, 09:06 AM
SD421's Avatar
Yes, and its because I think that Base/Clear makes these cars look too plastic and too shiny.
1966 GTO
KRE Tri-Power
Old 03-17-2015, 09:10 AM
2002Z4CSS's Avatar
Looks very shiney!
1971 Pontiac GT-37
Old 03-17-2015, 09:24 AM
Tempest's Avatar
looks great, nice job
keep us posted, and keep the pics coming.
Old 03-17-2015, 10:25 AM
geeteeohguy's Avatar
Looks great, Don. Remember when we did my '67 in PPG single stage? That was 1993, and it still looks pretty good....I agree with the single stage. Haven't seen a base/clear system yet that didn't peel after 20 years, and that's not good enough for me. The 30 year old single stage on my '65 even looks presentable....try that with a base/clear system on a street driven car.
Jeff
Old 03-17-2015, 05:47 PM
tripower's Avatar
tripower tripower is offline
Did a 65 Lemans vert in the same PPG single stage Concept in Montero Red in my garage. Only issue I had was being that I had was I could not get the outside panels to match what I did in the jams and under trunk lid since I did those on a different day with different temps, humidity, gun pressure, etc. Not a fault of the paint though! Agree with the results of the single stage PPG looking deeper and more like the original lacquer. Best of luck you'll love the results!
Name:	237679 - Copy.JPG
ID:	393034   Click image for larger version
Name:	237676 - Copy.JPG
ID:	393035   Click image for larger version
Name:	237677 - Copy.JPG
Norm J
Old 03-17-2015, 10:08 PM
6804gto's Avatar
6804gto 6804gto is offline
Originally Posted by SD421 View Post
Hi Guys,
Don
Concept is a excellent choice for a solid color, especially a red like you are using.
post some pics when you get the exterior done
Old 03-18-2015, 09:55 AM
77 TRASHCAN's Avatar
I agree with you!
Shut it off
Shut it off
Old 03-19-2015, 03:24 PM
SD421's Avatar
Your '65 looks real nice!
After the jambs were painted on mine, I wasnt sure I had the right color because it looks like a "Brownish Red" and not the deep red I remember. Sure enough, the color changes depending if there is light on it or not.
Don
1966 GTO
KRE Tri-Power
Old 03-23-2015, 02:18 PM
Birdguy's Avatar
Birdguy Birdguy is offline
I am currently doing the body work and paint on the '62 Catalina featured in the movie "Selma". After skinning it down to bare metal and completing the body work, I applied PPG DPLF90, followed by two coats of K38 to get everything leveled out. The color coat is the Aquamarine in PPG Concept DCC Single Stage.
I hope I have finally figured out the optimal settings to avoid the mottling and cloudiness that has plagued me up until now. The P-sheet recommends 2 wet coats, but that resulted in absolutely awful mottling even after setting the gun to get a good spray-out.
Am I alone in having this issue with PPG Concept? I welcome any advice and suggestions.
Old 03-23-2015, 03:04 PM
SD421's Avatar
What tip size are you using? My guy used a 1.3 tip
What Reducer ? I believe we used DX91. (There are I believe 3 different types of reducer with different mixing ratios)
Two coats were applied with a pre coat to give the paint something to hold onto.
Don
1966 GTO
KRE Tri-Power
Old 03-23-2015, 06:55 PM
Birdguy's Avatar
I'm using DT870 reducer and DCX61 hardener through a 1.4 tip. I tried doing what you did with the light starter coat and two wet coats following, but that gave me the mottled appearance even when making fairly quick passes 6-8 inches off the surface. What seems to work better now is to shoot several light coats waiting 5-10 minutes in between. It gives a fairly glossy finish with just a small amount of texture (not orange peel).
Old 03-23-2015, 08:19 PM
400 4spd.'s Avatar
Try some DT880 and see how it lays down. On the last coat add another 10% of 880.
