Old 04-24-2017, 01:14 PM
Tiger Paw Tiger Paw is offline
50lbs??, Only if the pump made of lead. Closer to 15lbs.
John, it looks like you use some weight on the front anyhow.
  #1322
Old 04-24-2017, 01:42 PM
Stan Weiss's Avatar
What about the tank and hoses?
Stan
Pontiac Pump Gas List
  #1323
Old 04-24-2017, 01:59 PM
cgeise's Avatar
cgeise cgeise is offline
I have all the stuff sitting right here ill weight it and report back but guessing no more that 25 total
  #1324
Old 04-24-2017, 02:02 PM
Elarson's Avatar
Elarson Elarson is online now
Add the weight of external pump, mounts, hoses, tank and some extra oil.
Subtract weight of internal pump, pump driveshaft. Also subtract weight of accumulator if so equipped.
Eric
  #1325
Old 04-24-2017, 02:52 PM
Maybe I misread John's statement but I read it as:
If you run a Dry Sump system then the racing org tacks on 5% times the engine CID or 28 pounds of carry weight plus the weight of the actual components and oil so assuming 20 pounds for that = 50 pounds. And about 20 pounds of that is in front of the engine.
  #1326
Old 04-24-2017, 03:55 PM
I used the lighter cloth braided hose, crimped alum fittings. My dry pan had less baffles in it and was pretty much a box shape. I was able to run a little less oil because the tank is tall and cylindrical. Many of dry sump pumps these days have manifold on scavenge out, which eliminates several hoses and fittings.
I did figure the best case as far as weight goes. And yes whatever weight will a little forward, about a foot?
Not trying to argue with anyone, just think the decision should be thought out with a thorough understanding. A 50lb weight penalty that's adds to decision!
  #1327
Old 04-24-2017, 03:56 PM
cgeise's Avatar
Originally Posted by John Langer View Post
Yes 5% of the engines cid in pounds. It isn't worth the weight for the added hp. Additionally it isn't worth the additional 50+'pounds on the nose.
That class has more rules that the Betty Crocker cook off -- for most guys the 20 some pounds is a cheap price to pay for some engine Insurance.
  #1328
Old 04-30-2017, 06:24 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Chassis Cert today at New England Dragway.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1329
Old 04-30-2017, 06:44 PM
Hooter's Avatar
Hooter Hooter is offline
Killer build Ed. Can't wait to see it in person.
67 Bonneville ragtop
  #1330
Old 04-30-2017, 07:14 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
6.0?
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
  #1331
Old 04-30-2017, 07:44 PM
RAIV-Z's Avatar
Originally Posted by twooldgoats View Post
6.0?
Yes, got a 6.00 cert today.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1332
Old 04-30-2017, 09:34 PM
Very Pretty Car Ed and looking forward to seeing / hearing about very good times with the car.
Good Luck and a very nice job.
  #1333
Old 04-30-2017, 11:09 PM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
I hope you bought stock in "depends"....
Calvin Hill
Hill Performance
708-250-7420
  #1334
Old 05-01-2017, 02:39 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Love the front view! Very nice work.
  #1335
Old 05-01-2017, 07:04 AM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Looks impressive! Good luck, be safe and have fun.
  #1336
Old 05-01-2017, 07:15 AM
GTOGEORGE's Avatar
Twin turbo RA5........ya gotta love it!
GTO George
  #1337
Old 05-01-2017, 07:29 AM
mgarblik mgarblik is offline
That 6.0 tag is an accomplishment by itself. Not easy to obtain first time through tech. Congratulations on that step. Not to mention the coolest engine package ever. Getting close.
  #1338
Old 05-01-2017, 09:15 AM
Beautiful piece! Good luck and go fast!
  #1339
Old 05-02-2017, 11:59 AM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
Very nice build! Best of luck with the beast...
  #1340
Old 05-02-2017, 05:36 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Paint is insane.
