Old 10-18-2022, 08:32 AM
Mr Anonymous's Avatar
Like previously mentioned, i cut some squares out of an old semi tire sidewall. Not bolted down at all. That's for the house garage's 60 gal upright. My homebrew 60 gal in the shop is sitting on a piece of OSB, 3/.4 thick. Both have zero floor vibration. I do like the idea of putting casters on them, I have everything else on wheels, my compressor is about the only thing that isn't, and I see no downside to doing it.
Clutch Guys Matter
53 Studebaker, 400 pontiac
1964 F-85 Home of the 700hp small-block Olds
**Still wanting a 64 Bonneville or Catalina**
Old 10-18-2022, 08:55 AM
JUDGE3 JUDGE3 is offline
Default R technology
wonder if the pallet guys left it on because they couldn't lift it off? lol check out the picture, I had to go it alone out here at my age and used redneck technology to get it off the dreaded "pallet mount".
my engine hoist would not go high enough to center the chain. the compressor wanted to really swing out even lifting a little. so being alone I strapped it to my truck hitch, and the other strap to the wall. worked perfect. came straight up just enough to kick the "shipping pallet only" out from under it and take it to the burn pile.
(please notice the 12 bolt posi marks in the shop. I love the smell of burning rubber in the morning. smells like victory!)
Old 10-18-2022, 11:49 AM
dataway's Avatar
dataway dataway is offline
On a couple of occasions I was very happy my compressor is on wheels. Like when parts roll behind it, or belts need adjusting. etc.
I even have my 2500 lb Bridgeport on wheels
Old 10-18-2022, 09:15 PM
Default Runnin
Got it wired up with 6 gauge and 40 amp breaker today.
runs great no surprises and is it ever quiet running. quieter than I even expected. the whisper system is pretty darn neat.
must have a ram air V oil pump. nice steady 50 psi
Old 10-18-2022, 10:13 PM
Bills Auto Works's Avatar
Bills Auto Works Bills Auto Works is offline
NOPE! I have a fork lift, so taking it off would have been a simple process. Your pallet is definitely a shipping pallet & I would not have left mine on that either. The pallet mine is still on after 20+ years is much smaller & lower to the ground using stronger boards. Sorry no pictures.
God Bless
BIll
https://www.jalopyjournal.com/forum/...closed.614419/
"Jealousy is a Sad Pathetic Character Trait Generally Held By The Lazy, Immoral Dregs of Society"
Your QUALITY Pontiac Transporter Since '83
1955 Chevy Alt. W.B. Gasser
1955 Nash Ambassador Cust Lemans
1957 T-Bird
1964 Grand Prix
1966 Catalina Conv
1966 Ambassador DPL 2dr
1966 Ambassador Cust. 2 DR
1967 Marlin
1967 Toro
1973 Nova Chassis Car
1992 Jag XJS Conv
1992 Jag XJS Coupe
2007 Cad XLR-V Supercharged Roadster
2008 Avalanche Southern Comfort Edition
Old 10-18-2022, 11:44 PM
dataway's Avatar
Oil pressure gauge is very cool.
Old 10-19-2022, 09:35 AM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
While you're plumbing it up, consider an automatic drain timer? There are options online from $30-$200. I think I have this $48 one: https://www.amazon.com/Electronic-Au...dp/B00UEU6XIE/
Both of my big compressors are still on the pallets - one from 30+ years ago when my dad bought it!
Mike
Old 10-19-2022, 09:57 AM
Default compressin'
Rats! foiled by the wood pallet guys yet again.
Thanks, I may put one of those auto-drains on. like that.
used the excess horse mat for my bench top. iv'e always used this stuff for the bench tops. can cut various pieces for block sanding to.
emax use's 2 belts for less tension on the pullys, low rpm motor.
Old 10-19-2022, 12:52 PM
Sirrotica's Avatar
The manufacturer (Chicago Pneumatic) answers why you should not keep your air compressor on the original shipping pallet:
https://compressors.cp.com/en-us/exp...or-on-a-pallet
The reason mostly hinges on the pallet rotting, and the upright compressor falls over, they also site noise amplification on concrete. Since I bought my current home with 2 compressors left on the premises, I have one shop area with a wooden floor that has the compressor sitting on the wooden floor. It's been in there for at least a decade. The one at my old house has been sitting on the shipping pallet since i bought it new around 2006. The pallet hasn't rotted yet.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
