Old 09-05-2024, 10:28 PM
blueghoast's Avatar
Originally Posted by JLMounce View Post
The link to the podcast is up, it’s good, go watch/listen.
He stated the intake was moved towards the center by around .080 and the exhaust moved towards the chamber edge by about .030. That was his best recollection.
He also claimed the heads will work on a 350 block as long as the chamfers are in place.
But seriously take the hour and 15 minutes to watch the podcast instead of making assumptions based on 3rd hand knowledge of people like myself.
X2
GT
  #62
Old 09-05-2024, 10:35 PM
JLMounce JLMounce is offline
Originally Posted by MatthewKlein View Post
Is it in this thread? Or could you please post it here
It’s been posted in a previous page. Here’s another fresh link.
https://www.youtube.com/live/O5f5ASA...N397-BphQER8Dw
-Jason
1969 Pontiac Firebird
The Following 3 Users Say Thank You to JLMounce For This Useful Post:
  #63
Old 09-05-2024, 10:40 PM
Dragncar Dragncar is offline
Not sure why special pistons would be needed. My High Ports have a 2.20 valve and generic Butler Ross pistons, 4.155 bore.
  #64
Old 09-05-2024, 10:42 PM
MatthewKlein MatthewKlein is offline
Thank you
  #65
Old 09-05-2024, 10:57 PM
We live in an amazing era. Can you imagine access to an interview like this with Vic Edelbrock, Mickey Thompson, Duntov or Barney Navarro
  #66
Old 09-05-2024, 11:12 PM
slowbird's Avatar
slowbird slowbird is offline
Your butler pistons are based on eheads. If you move the intake .080 you think the valve will still line up with valve pocket in the pistons?
That .080 plus a 2.19 intake valve is like running a 2.270 valve in eheads. How many shelf pistons have pockets for that? Guessing not many.
  #67
Old 09-06-2024, 12:13 AM
jhein's Avatar
jhein jhein is offline
https://www.youtube.com/live/O5f5ASA...IK0UOC7Aut&t=4
The Following User Says Thank You to jhein For This Useful Post:
  #68
Old 09-06-2024, 03:37 AM
The pistons have one big valve pocket that is the same one both sides of the piston and its big enough for a 2.20 intake valve on both sides.
Move that intake .080 towards the middle and there is nothing but room. And the other side is big enough for a intake valve so why would a exhaust valve hit anything ?
Am I missing something ?
  #69
Old 09-06-2024, 08:48 AM
slowbird's Avatar
Yes you are. Not everyone runs Butler pistons. Also did you check radial clearance on your pistons? .080 is a noticeable move.
Don did a good thing by moving the valves but he might have created other issues by doing so.
The Following User Says Thank You to slowbird For This Useful Post:
  #70
Old 09-06-2024, 09:02 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Butler pistons have some of the largest valve pockets in the industry "for a reason".
If the information posted in this thread about valve sizes and relocated valve guides is correct one better be sure to check the piston to valve clearance carefully and in all directions.
A 2.11 intake valve has the potential to flow 350 plus CFM in a standard port Edelbrock head.
A 1.66 exhaust valve will support 900 plus horsepower.
Go fast, see Elvis!
  #71
Old 09-06-2024, 09:58 AM
adamo adamo is offline
Why doesn’t anyone ask don if they will need dedicated pistons? Or is everyone doing the liberal thing and talk and complain with out even knowing anything?
  #72
Old 09-06-2024, 10:18 AM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Something else to note as far as quality details he mentions is that they will have Helicoils for rocker studs and exhaust bolt holes
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
  #73
Old 09-06-2024, 10:19 AM
Cant wait to see the 48s flow test ! As cast model program showed potentially 320 cfm
  #74
Old 09-06-2024, 11:00 AM
jhein's Avatar
I just posted the question in the comments for the video. He has been responding to some so we'll see,
  #75
Old 09-06-2024, 11:04 AM
jhein's Avatar
Wow, that was fast. Here's his response:
"I did move the valves a little but hoping most available pistons will work. As we get things sorted out I will share that info."
  #76
Old 09-06-2024, 12:22 PM
slowbird's Avatar
Interesting
  #77
Old 09-06-2024, 12:34 PM
See how easy that was.
  #78
Old 09-06-2024, 01:23 PM
PAUL K's Avatar
Not sure if we know more now than before??
Go fast, see Elvis!
  #79
Old 09-06-2024, 01:37 PM
We probably won't realistically have an answer to that until the first couple castings get machined up. Don will learn a lot from that program.
He has 4 total castings right now. He intends to machine them up and work out that program. He'll then flow an intake and exhaust port on the D port and one of the round port heads. Then he intends to cut them up to make sure there's no issues with the castings, water is where it's intended etc.
I'm sure at that time he'll have a better idea whether or not there could be a piston selection issue. Given the stated goal of these heads, it probably doesn't make business sense to have these go out the door to only people that will be doing a new build at the time and can select appropriate pistons. That's my speculation anyhow.
-Jason
  #80
Old 09-06-2024, 01:45 PM
slowbird's Avatar
He didn't answer anything.
The Following 4 Users Say Thank You to slowbird For This Useful Post:
