Old 07-23-2025, 11:21 AM
65madgoat's Avatar
Default 1971+ rear alternator bracket strap MOUNTING pics please
Can anyone provide a pic of the rear alternator mounting bracket mounted on 1971+ firebirds?
I know the one side uses that stud on the thermostat housing, but would like to see it mounted to the head - what stud/bolt is used there and how it holds the alternator.
Also, I see this strap is apparently and oddly not reproduced - used ones get listed for "1971-1974" sometimes and 1971-1979 on other sites. Reason for?
Thank you.
https://www.firebirdcentral.com/1971...p/enc-2232.htm
Old 07-23-2025, 05:05 PM
Formulabruce's Avatar
The 70 rear bracket looks similar, but it is way different. Listing should be 1971 to 1975 IIRC. in 76 the alternator bracket changed on the front side and many cars didn't use a rear bracket.
The intake side just slides on a intake bolt/ stud
" Long may we DRIVE !"
Old 07-23-2025, 09:01 PM
Pepi's Avatar
Pepi Pepi is offline
Default Rear Alternator Pictures
Here are a couple pictures I had on my computer from my 73. I will try to locate some more.
ID:	654868   Click image for larger version
ID:	654869   Click image for larger version
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
Old 07-23-2025, 09:25 PM
Period, I noted your spacer.. I gotta look that up in the assy manual.. thanks for pics!
Old 07-23-2025, 09:39 PM
Most common '71+ rear alt bracket was used with 71+ 10SI alts like the 927's & 928's.
Less common '71-76 Pontiac alternators were the large case 27SI alternators like '71-73 1101015's and the later "1024"s & "1016"s. This setup required an 80 AMP only rear bracket, & were used on '71-76 Pontiacs with factory AC and Rear De Ice (grid style defroster). This set-up is what we are seeing in PEPI's pic of his F-body's 80 amp Alternator.
Have rear brackets for both styles, stocked fairly deep on all 80 amp Pontiac pieces EXCEPT Idler pulleys & fixed front 80 amp alternator brackets.
Old 07-23-2025, 09:46 PM
65madgoat's Avatar
Thanks all. Those pics help. I did also notice that spacer on yours.... appreciate it.
Old 07-23-2025, 10:11 PM
Held for Ransom's Avatar
'71 set up...
https://forums.maxperformanceinc.com...d.php?t=383724
So long, farewell.
Old 07-23-2025, 10:38 PM
65madgoat's Avatar
Thanks man. I see on that thread for the 1971 set up the 2 little steel p/s pump brackets appear to NOT be painted - mine originally showed no signs of black paint either. Wonder if some got black paint and some didn't. As you typically see them painted or powder coated black today.
Old 07-31-2025, 01:38 PM
65madgoat's Avatar
@ol Pinion head -- your inbox is full
Old 07-31-2025, 01:54 PM
Stan65 Stan65 is offline
Pepi,
A little derail, your 73 looks to be the 2nd design emissions system. Do you have the Distributor Spark Delay Valve circled in orange in this picture? Looking for any info on this valve for 2nd design 73.
Thanks,
Stuart “Stan” Landreth
The Following User Says Thank You to Stan65 For This Useful Post:
Old 07-31-2025, 05:55 PM
Pepi's Avatar
Stan,
Mine is the late 2nd design emissions. I do not have that spark delay valve. When we bought the car 43 years ago, the original owner had put a Holley carb on it, but kept the original and we put it back on. The original white striped hose always went from the TCS solenoid to the distributor. Recently I started looking again for one and found one at $300, but when I look at the parts manual, I didn't see where it was listed for my engine. I am starting to wonder if not all engines got it.
Thanks,
Karl
Old 07-31-2025, 07:14 PM
70TA-RAIII 70TA-RAIII is offline
Here's some pics of the alt bracket on my 71 TA 455 HO. Can't swear they are 100% correct but they look it to me. No spacers between bracket and alternator on mine.
John
70 TA RAIII M20 05D
70 TA RAIII M20 06B
The Following User Says Thank You to 70TA-RAIII For This Useful Post:
Old 07-31-2025, 09:14 PM
Pepi's Avatar
I noticed your bracket is bent towards the alternator whereas mine is bent away from it, thus requiring the spacer. Item 19. According to this it is for 71-74.
Name:	Alternator Parts Catalog.jpg
Old 07-31-2025, 10:08 PM
I see that on the drawing. I may very well be missing the spacer and someone may have just tightened the bolt up without the spacer, probably using a shorter bolt than original.
I don't know as much about these 71-up setups.
John
70 TA RAIII M20 05D
70 TA RAIII M20 06B
Old 08-01-2025, 06:07 AM
Don't confuse the 80A alternator to the 37/55A units.
So long, farewell.
The Following 5 Users Say Thank You to Held for Ransom For This Useful Post:
Old 08-01-2025, 05:09 PM
Pepi's Avatar
Good point!
Old 08-10-2025, 03:38 PM
Originally Posted by Stan65 View Post
Pepi,
Thanks,
Stuart, start a new thread trying to ask that question on info. I'll try to answer.
So long, farewell.
Old 08-11-2025, 11:42 AM
HFR,
Appreciate the offer! I did find it. Just had to pay attention and read bulletin 73-T-21A. It was right in the chart. Concerning 455’s, only wagons got the Spark Delay Valves. Other displacement were hit and miss.
Photo stolen from JohnTA1.
Thanks,
Stuart
Old 08-11-2025, 06:31 PM
Pepi's Avatar
Boy, do I feel like an idiot. I have looked at that chart before and never looked all the way to the right and noticed the column that mentioned Spark Delay Valve. That would have saved me a lot of hassle looking for one. Now I have to see if the chart I have has that column. But does confirm that I do not get it on my engine.
Thanks for that!
The Following User Says Thank You to Pepi For This Useful Post:
Old 08-11-2025, 06:38 PM
Pepi,
Same here lol. I just kept looking at the picture showing the delay valve. I bought an incorrect NOS one for what I believe is the applications that do use it. I definitely paid too much for it and now don’t need it.
Thanks,
Stuart
