Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 10-16-2025, 09:42 PM
Speargun's Avatar
Speargun Speargun is offline
Default IA Aluminum 535 For Sale
I don't really need 650 HP+/- in my '67 Firebird to get groceries or drive uptown on the weekend so I'm letting my aluminum 535 go to someone who can put it to better use.
ALL parts were new when the engine was built and it might have around 2500 miles on it now. Runs great on 92 octane.
I took it to the track in Gainesville once for test & tune and it ran 11.804 @ 121.79 with a 2.014 60'. It spun the 275/60R15 Nitto's halfway through second gear so there's more to be had...
The basic specs (off the top of my head) are below, but if you're serious about buying it, I can provide more detailed information.
Speedmaster heads with all new parts (Manley valves / springs are good to .700 lift) and have been CNC ported to 340cfm.
Aluminum IA block with a forged rotating assembly.
Dish pistons for a SCR of 10.7:1 cold.
Standard bore HR cam (.622" lift & 112 lsa (iirc) with Scorpion 1.65 rockers).
Aluminum mechanical water pump with clearanced divider plate.
Canton road race oil pan for a '67 Firebird.
$19,500 obo heads to oil pan.
Located in Silver Springs, FL 34488 (Central FL)
I sold the Edelbrock Pro-flo 4, Super Victor EFI intake, & distributor I was running on it, but I do have other parts available if you're interested.
Complete multi-port injection system
  • Holley Terminator X w/dual sync distributor & GM trans controller NEW
  • Super Victor EFI intake (Dominator flange) NEW
  • Injector rails for Super Victor NEW
  • Edelbrock 80lb/hr injectors Used
  • Intake elbow (Dominator flange) NEW
  • 102mm LS style throttle valve NEW
Victor intake (Square bore) NEW
Warrior intake (Square bore) NEW
MSD Ready to Run distributor Used
MSD Pro Billet distributor (Locked for timing control) Used
Video of engine running:
https://photos.smugmug.com/photos/i-...BTZMS-1280.mp4
No!
Do not try!
Do! Or do not.
There is no try. - Yoda
1967 Firebird Restoration 2005 - 1/25/2017
The Following User Says Thank You to Speargun For This Useful Post:
Old 10-17-2025, 07:15 AM
mysticmissle's Avatar
Great deal I'm Sure it won't last
Old 10-20-2025, 04:19 PM
joes455 joes455 is offline
What cam specs?
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 10-21-2025, 08:23 PM
ponjohn's Avatar
ponjohn ponjohn is offline
What camera did you use?
Old 10-26-2025, 01:14 PM
Speargun's Avatar
Google Pixel 9XL
No!
Do not try!
Do! Or do not.
Old 10-26-2025, 01:19 PM
BADDTA's Avatar
BADDTA BADDTA is offline
Good luck!!!!
Boobs & bacon
Old 12-31-2025, 08:13 PM
Speargun's Avatar
Finally got around to digging up the specs for this engine.
IAII aluminum block, 4.35 bore
SCAT Forged Crankshaft 4.5" Stroke,
SCAT H-Beam 6.8" Rods w/ARP 2000 Bolts,
Race Tech Dish Pistons, 29cc
Comp Cams Hydraulic Roller (1.65) .660/.629 252/262 @ .050.
Morrell High RPM Hydraulic Lifters
New timing cover 69-79
Cloyes 9 Keyway Billet, True Roller
1 Piece Reinforced Oil Pan Gasket
Canton road race oil pan, pick up, and Mellling oil pump
Speedmaster 72cc, CNC "Fast Burn" Chamber
CNC Port heads includes head bolt sleeves. 340cfm
Manley Valves, 2.19/1.77
Springs, Retainers, Seals, and Locks for .650" lift
Deck Clearance .050" - "Piston .010 Below Deck & .040 Gasket"
Head Studs for Edlebrock/Speedmaster Heads on Aluminum Block
Static Compresion Ratio 10.67:1
Dynamic Compresion Ratio 7.997:1
No!
Do not try!
Do! Or do not.
Old 01-01-2026, 11:47 AM
ponjohn's Avatar
I eamiled you, not in reference this engine.
Old 01-01-2026, 04:33 PM
Dlaw455 Dlaw455 is offline
Butler may be interested in that super victor efi manifold. I managed to find a new one and sent it to them earlier this year for pprting and they were asking if I knew of any more available.
1969 Firebird
525 IA2 Aluminum Block
Edelbrock Wideport heads
200 4r trans
3.89 9"
Old 01-02-2026, 05:13 PM
opeliac opeliac is offline
I have a brand new 4500 version...On the fence about using it or buying a billet.
Old 01-02-2026, 08:46 PM
gobrdgo gobrdgo is offline
That engine deserved a proper set of slicks for that pass! Love it.
Old 01-03-2026, 01:03 PM
Speargun's Avatar
The car just isn't transferring like it should. With coil-overs up front, split mono leaf springs, and Caltracs, it should stick & git! Mid to low 10's should be easy.
I'm starting to think that the Continental "Jim Hand Special" converter doesn't have enough stall. It was built to stall around 3600 rpm, but it was built tight for the street and, if my calculations are correct, it has 8% slip running through the traps.
No!
Do not try!
Do! Or do not.
Old 01-07-2026, 01:52 AM
blueghoast's Avatar
Put some negetive pinion angle to it, It'll hook.
GT
Old 01-08-2026, 02:31 PM
KGTO's Avatar
KGTO KGTO is offline
Hi there... I sent you a PM along with my number
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @164 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
Old 01-09-2026, 12:02 AM
blueghoast's Avatar
Sorry but I didn't receive your PM maybe try again.
GT
Old 03-04-2026, 06:08 PM
bb463700 bb463700 is offline
Just sent you a PM.
Old 03-05-2026, 08:02 PM
blueghoast's Avatar
.For some reason I'm not recieving any massages and can't figure it out
Call me 269-832-8122
GT
Old 03-06-2026, 05:31 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Nice, GLWS, if this was a couple years ago I would've bought this during my engine debacle.
Easy high 10 engine here, pump gas beast.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
