Old 04-03-2026, 08:14 AM
PAUL K's Avatar
PAUL K PAUL K is offline
IMO E-85 has its place and it's a very narrow one. I know a handful of guys that compared E-85 to racing gas at the dragstrip.... everyone went faster with race fuel. I know one professional builder that melted a piston while following advice from a popular E-85 carburetor builder tuning an engine on a dyno. The only reason he followed the advice was due to the engine being so far down on power compared to the race gas.
Go fast, see Elvis!
Old 04-03-2026, 09:19 AM
Pigeon's Avatar
Pigeon Pigeon is offline
Default E85
Paul, thanks for your response and thanks to everyone for your input. I read this site all day.
I guess I’ll pass on the E85 stuff.
This winter I converted my front suspension to true double adjustable coil overs, not the large diameter adapter springs that put all the weight on bottom dog bone style bottom mount. I fabricated my own low mounts for my tubular control arms. Besides a little weight savings I don’t really expect a performance gain. I’m gonna attempt to send some pictures which will probably be upside down or sideways
1964 GTO, 488 cubes , 340 cfm E heads by butler 268/276 on 110 solid roller. .440 lobes 1.65 hs rockers. 12.5:1 . Single 4150/1050 cfm carb by ATM. Back half ,ladder bar, foot brake. 8” ati , home made th400 with 2.75 low gear set and 4.10:1 rear. Stock block splayed billet, Eagle forged rotating assembly. 3050 lbs with driver. 9.25/142.5
100 pct home made. Bucket list dream checked off!
Old 04-03-2026, 09:53 AM
grandville455's Avatar
I’ve went from pump gas to e85, while there has a been a slight gain, going from 9.42 to 9.38 NA at 3500 lbs,it’s the cost that has been the biggest gain, my mileage is also slightly down but it’s been a fun journey, I did a bunch of research and talked to the right people and built my own carbs over the years and the current E85 one also. My comp is like 13:1 and cranking psi of 205, being retired I would stick with what’s been working for you!!
Darby
M/T 275/60 ET SS Drag Radial
Old 04-03-2026, 10:32 AM
Pigeon, is this a race only car?
If it is why go E85? Go to straight methanol.
Ethanol is a step up from gas, but methanol is a lot better and has more power too. If you're buying/adapting stuff for the E85 not much more work to make it methanol.
With the right setup it will make more power.
But you can't think like it is gasoline.
Old 04-08-2026, 02:34 AM
Probird's Avatar
Probird Probird is offline
John knows. Methanol will pick your car up over the race gas. It’s makes a ton more torque. If I were you I would go with a dominator set up for alcohol over a 4150 style carb. As far as the transbrake picking the car up…. If your converter is set up right you won’t gain much of anything with a transbrake. It’s more fun but not necessarily faster. We have a car that runs E-85 and it did pick it up a little bit and was cheaper than race gas while running cooler.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
2024 Chief of the Pontiacs
Old 04-08-2026, 02:14 PM
Region Warrior's Avatar
Agree 10p% with methanol at your power level.
Way much power vs e85 on a buddy's 13.cr on his 440.
Last year was 95% or more consistently to vs e85 at any pumps here.
Plus smells better. Or less....
Old 04-08-2026, 02:19 PM
Damit. Agree 100%.
Old 04-08-2026, 02:44 PM
JJg bout smell. I can barly.
And nearly colorless so carefull of any leaks on hot engine.
My bud got nasty burn on hands one time. Worse part smacked his knuckles under top of hood.. just saying....
Old 04-13-2026, 01:14 AM
blueghoast's Avatar
Love the limiter, NICE
GT
Old 04-13-2026, 08:05 AM
Pigeon's Avatar
Default E85
I feel a metal on metal travel limiter on the front suspension has to shock the back tires to abruptly.
After you spend all kind of money on double adjustable shocks to make everything articulate at a controlled rate it seems counter productive to then have metal on metal so I put that stiff little coil spring on the all thread. The travel is adjustable with the nylock nut and the bottom of the rod is mounted with rubber shock bushing to also help soften the same negative effect.
