Thanks!! I have the same welder...
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
Hmm... I've got to learn the new jargon... what I've always called "heat risers" became E.F.E. systems!
SteveOw- any "theory" behind your removal of the center ports divider?
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926}
Well, you learn something new everyday. So the heat riser flapper thing went away in '69 and came back again as part of the emission control system in the mid '70s?
Jack, that center port divider is another thing the Pontiac engineers changed their mind on- I've got a bunch of sets of logs and only a couple have the divider. I don't recall the dates on the ones with them or without. The set on my Lemans right now are '70 castings that don't have the divider. BTW, my lemans ran a 12.76 at Lebanon Valley yesterday with logs... and G70-14 Polyglas tires. Those log manifolds aren't the hinderance that most people believe!
1966 GTO 1969 Lemans Convertible- F.A.S.T. legal family cruiser. 12.59 on G70-14 Polyglas tires. 1.78 60' 1969 Bonneville Safari- cross country family cruiser. . 1979 Trans Am 400, 4-speed, 4 wheel disc. View from the drivers seat racing down Atco Raceway- http://www.youtube.com/watch?v=GhYDMdOEC7A Ride along in the other lane-http://www.youtube.com/watch?v=mIzgpLtF_uw |
![]() Early Nov. 69 car,....... manifolds weren't that much earlier from memory.Thanks for the thread too b-man. Last edited by 70Steve; 06-19-2010 at 11:39 AM. |
unless you are doing a 100 point resto, id leave it out, and even if you do a 100 point resto, id tack weld it open.. ![]() i think opening up the log outlet and extrude hone polishing sure cant hurt..plus with good mandrel pipes that dont neck down you should be good up to 1hp/cu in....
Is the heat riser necessary with an automatic choke?
Some years didn't have the flapper at all. So, no not necessary.
