#361
Old 07-25-2012, 02:11 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Why did you say "cable driven"? I haven't seen that since '57 FI Chevy.
  #362
Old 07-25-2012, 04:55 PM
Bill Bolin's Avatar
Bill Bolin Bill Bolin is offline
I believe NASCAR is now using cable driven fuel pumps.
  #363
Old 07-25-2012, 05:00 PM
cgeise's Avatar
cgeise cgeise is offline
thought they went to electric ??
  #364
Old 07-25-2012, 07:19 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Originally Posted by jdw_poncho View Post
Did you get a mandrel drive with it as well? I ended up using a ATI mandrel but have doubts about it being ok on the street while running a alt pulley off of it. Im looking at mounting a alt pulley then the mandrel for the pump to get the stress off of the mandrel.
Better buy a few extra belts, I ended up purchasing a few spare belts from my local Motion industries. If you mount the drive off a aluminum motor plate you'll see flex in the plate when you try to tighten the belt. Without the trans attached I could move the motor back and forth just by squeezing the belt between the pulleys. This caused me a belt tracking issue when the trans was bolted up. Just a FYI
No mandrel yet got the BBC beltdrive kit "PN\252035BB though. I'll pick up some spare belts once it's installed and running. I have an AllPontiac steel front plate on the engine right now. How's you tin work coming along?
  #365
Old 07-25-2012, 07:23 PM
RAIV-Z's Avatar
The fuel pump is mounted in the back near the fuel cell, driven by a cable.
  #366
Old 07-25-2012, 08:33 PM
One less thing to worry about on a "Street Car", Jack, LOL.
Having the fuel pump crap out on you while you are driving to the burger whopper,
(on on a Hot Rod Power Tour event!!!)
Tom Vaught
  #367
Old 07-25-2012, 09:57 PM
jdw_poncho's Avatar
jdw_poncho jdw_poncho is offline
With the steel front plate you wont have a bit of problems on the belt tracking.
Just dropped the car off tonight. He thought it should be done by next Wed. As soon as its back I need to install the windshield and engine/wiring. Had he responded a week sooner the car wounld have made it to norwalk. Of well there always next year.
I decided to use a matte black finish, they didnt have any natural brushed aluminum so I settled on black. Hope it turns out ok, I'll post up a few pics next week.
  #368
Old 07-26-2012, 01:47 AM
Pictures of the cable/sheath and drive spindle/pulley, etc.?
  #369
Old 07-26-2012, 02:07 AM
john marcella john marcella is offline
I would like to get a hold of this head. I kinda got an idea
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
  #370
Old 07-26-2012, 09:19 AM
RAIV-Z's Avatar
I'll take some pics when I get home. No cable yet, got to install all the parts, then measure to determine the length.
  #371
Old 07-26-2012, 05:37 PM
RAIV-Z's Avatar
I'm all ears!
btw... Your mailbox is full.
  #372
Old 07-27-2012, 07:05 PM
RAIV-Z's Avatar
Here you go.
ID:	292569   Click image for larger version
  #373
Old 07-28-2012, 02:14 AM
Thanks. I look forward to some mock-up pictures.
  #374
Old 07-30-2012, 01:05 PM
RAIV-Z's Avatar
Valve lash as measured cold a few weeks after delivery. Valve lash cold was set to 0.020 according to both build sheets. What do you guys typically see for before\after lash measurements with new aluminum heads? The engine was on the dyno on two separate occasions.
Even Cylinders Intake Exhaust Odd Cylinders Intake Exhaust
8 0.016 0.009 7 N\A N\A
6 0.013 0.013 5 0.014 0.013
4 0.016 0.016 3 0.016 0.016
2 0.018 0.011 1 0.016 N\A
N\A indicates no measurement was taken by me before before disassembly.
Below are the plugs.
ID:	292925   Click image for larger version
  #375
Old 07-30-2012, 01:06 PM
RAIV-Z's Avatar
I'll post some pics once it's mocked up.
  #376
Old 07-30-2012, 01:32 PM
Plugs wont show all unless the motor was shut off "clean" at the end of a full power pass or dyno run pull. About all you can check otherwise is for erosion or porcelain boil other "damage" or excess heat signs. Idle gennerally darker than cruise but all out power on fresh plugs should see no to very little color on porcelain. The ground strap and base "carbon" ring are primary considerations then tip and porcelain condition.
http://www.wallaceracing.com/plug-reading-lm.html
Shrinking lash ??? interesting.
  #377
Old 08-01-2012, 12:50 PM
RAIV-Z's Avatar
Got confirmation that a replacement header flange is in the mail…
  #378
Old 08-02-2012, 10:35 AM
RAIV-Z's Avatar
Originally Posted by NHRASuperStock455SD View Post
We have guideplates no problem. They are standard issues.
Pushrod guideplate design looks like they need a little more work.
ID:	293191   Click image for larger version
  #379
Old 08-02-2012, 10:46 AM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
WOW!!! Are you kidding me!!!! Were the rocker studs loose?? Is that a crack just to the right of the weld?
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
  #380
Old 08-02-2012, 11:11 AM
Aluminum in the guide plate stud hole shouldnt be there... does look like a crack next to the weld but could be only a scratch, the pics arent 3D...but it does look cracked.
WTH... did they hire a guy that was down the road with a sign will "work for food"?
