Here are some pics of the bar. I also was told it has a pair of moroso rear racing springs. 29.5 x 10.5 tires. Again, this is how I bought the car but with my engine.
Car went straight with the 400 running 11.40's. Footbraking it seems to leave straight, but the t-brake is a white nuckle ride. But then it's my 1st t-brake car. I don't want to get hurt in this monster or hurt anyone else.
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
I can't tell in the pics if the lower control arms are boxed or not.
You may want to look at changing out the control arms as the next step.
68 Firebird Are you running with the wind or breaking it? |
Brian Rock '65 GTO - Pump gas 496" IA2 w/ High Ports, 200-4R trans, 3.73 gears, 275 Hoosier radials, and 3925 lbs. 9.88 @ 134 N/A on Cali 91 octane. http://www.youtube.com/watch?v=NJEIY5OJ68g
The LCAs are South side machine bars. They are rectangular box tubing, but I wonder about the relocation brackets being equal and square to one another. The relocation is probably a good thing, but everything is suspect at this point.
How old are the tires? The one time that I tried a 28x10.5 slick on my car it was ALL OVER the place. Your rear wheel looks narrow. I think that that was most of my problem. The 10.5 tire with an 8.5 wheel was pretty squirrely for sure. This was a stiff wall tire with tubes and it was still a dangerous mess. The 275/60 DOT radial cured all of that but they still prefer a 10" wheel to get a good footprint.
Wheels are 15x10 but the tires & tubes could be 5+ years old.
I installed a set of SSM bars on my 65 years ago to set pinion angle. Ya grind on each bracket till you get the angle you want. Hit & miss at making them equal. I think it was "Screamin Chief" who said they don't work below 11.00?? I'm considering buying the whole kit from HRparts. U&L arms and the bar. Always dreamed of my 65 pulling the wheels, but changed direction. Awesome & not light either.
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" Last edited by Old Goat Racer; 10-22-2012 at 02:43 PM. |
Looking waaaaay to serious in the photo of the 65! Bet you just lost the round previously by .0005 and was taking a T&T pass to relax.
74 GTO Bracket/Street car and another 74 for the wifey to race with! 70 GTO 400, 4 spd, #'s matching and a little to nice for me to own. Friendship is like peeing your pants..everyone can see it but only you can feel the warmth! |
The HR stuff is good quality. The urethane still allows some deflection though. Take a look at this http://trzmotorsports.com/wordpress/...sion-1968-1972
These control arms and the bolt on HRParts rear AS bar work well together. As far as the relocated IC via SSM bars or the Dick Miller no-hop setup that I used to run, what I have found is that somewhere imbewteen stock location and the drastically altered location seems to be the happy place for my car. Only the specific chassis and ride hieight will determine what setup you need. It's a good idea to plot your IC and see just what you have. There is no "magic" IC distance and height to shoot for. Once you are in the ball park and can get the car to seperate, you can tune with shocks to tighten things up/slow things down if needed. I'm around 40" out and 8.5" up right now. I ended up extending my lower control arm brackets at the rear end so that the control arms didn't point downhill from back to front. The first hole is 1" lower than stock, and the bottom hole is 3/4" below that. I'm in the bottom hole right now and the car finally seperates enough to where I need to start slowing it down with shock extension adjustment. It's all just trial and error.
Great info. Your car leaves perfect if there is such a thing. I noticed that your car does every thing right moves forward while seperarting and transfering, all at the same time. No wasted movement at all. I didn't know they had housing bearings like that either. Thanks again good info. GT. |
Pretty sure that was when I won Megabucks in '03. Bret Kepner took that pic.
I bought the whole kit HR-1909. with Delrin bushings. Set pinion angle at 3 degrees.
Went to the track ready to hang on and Walla, it went straight arrow. Money well spent.
Good deal!
