#561
Old 12-24-2012, 12:14 AM
Originally Posted by warriors revenge View Post
many years ago, when Dan Whitmore would do a "race port" job on a set of RA IV heads, he would break thru the pushrod hole, and epoxy a bronze sleeve in there to seal the port up.... the same should be able to be done for a head bolt....
just sayin
Head Bolt IS Different BECAUSE, a Head Bolt is torqued to a given condition by reacting against the head and its support structure.
So now you have cut away the support structure and you want to put a "push rod bronze sleeve" back in to seal up the hole but you think nothing about the loss of clamp load on the head gasket at that point on the head?
I have seen guys narrow the boss between the two runners on a normal cast iron Pontiac head and later they could not hold a head gasket. A cast iron head, not a softer aluminum head. Sorry but I think that you are missing the point here. It is not to seal up the oil leakage, etc, it is to be able to properly clamp down the head and have a head gasket hold under high boost pressures.
Tom Vaught
  #562
Old 12-24-2012, 09:51 AM
Elarson's Avatar
Elarson Elarson is offline
Tom Vaught
When I designed our billet RAV heads for the funny car, the very first design parameter was to define a 1/4" wall around all of the head bolts. NOTHING that was put in after that (ports, oil drains, etc) was allowed to violate that space. So far, the head gasket sealing is excellent even with the violence of nitro.
Eric
  #563
Old 12-24-2012, 11:16 AM
Elarson's Avatar
For an NA application, where cylinder pressure is lower and port flow is more critical, a thinner wall is the correct approach. Every design is a compromise to suit the specific use.
Eric
  #564
Old 12-24-2012, 05:43 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Eric
Hi Eric,
So what you’re saying is that on a boosted engine, this is not what you would have done? Got any of those billet V heads “with water jackets” or any suggestions to make my V heads work with with at least 25lb of boost?
Merry Christmas to all.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #565
Old 12-25-2012, 03:05 AM
Elarson's Avatar
Our billet heads don't have any provision for water jackets.
I haven't seen your heads so I'm not really qualified to comment.
Eric
  #566
Old 12-25-2012, 10:45 AM
For an NA application, where cylinder pressure is lower and port flow is more critical, a thinner wall is the correct approach. Every design is a compromise to suit the specific use. Eric
When you are doing Boosted Engines, Boosted Engine Engineers do stuff for Reasons!
Tom Vaught
  #567
Old 12-28-2012, 09:49 PM
RAIV-Z's Avatar
Originally Posted by taff2 View Post
Shouldn't you have a seat support tube under the driver,from the outer floor tube to the inner floor tube? Looks good though.
You're right, there should be a seat support bar. It wasn't installed yet.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #568
Old 12-29-2012, 10:30 PM
jdw_poncho's Avatar
jdw_poncho jdw_poncho is offline
Looks good Ed, any updates on the heads?
  #569
Old 12-29-2012, 11:01 PM
twinturrbo406's Avatar
twinturrbo406 twinturrbo406 is offline
Eric
... another alternative is to use a "Port Intruder" ... you machine out the head bolt area to a much larger size until it just machines into the floor/radius a small amount, machine a clearance hole on the bottom of the "Port Intruder" (solid aluminum round stock) to clear the shorter stud/nut under the "Port Intruder" ...
... then the ports can be CNC'd, or hand ported to size and the "Port Intruder" gets installed after the heads are installed, all the intruder does at that point is seal oil, and provide the interior shape of the two intake ports in that area, this is obviously a mod for a wedge layout ...
... well, i've only seen it done on a Wedge ...
  #570
Old 12-29-2012, 11:21 PM
Agree, A Port Intruder method of clamping down the head would work. A lot of extra machine time but the heads would probably stay sealed under boost. Typically requires a Big Hole though and the correct torque values for the shorter fastener.
Tom Vaught
  #571
Old 12-31-2012, 07:10 PM
RAIV-Z's Avatar
Thanks, all the major welding is done only a few more bars to add. The cage should be back in the car sometime next week. Regarding the RA-V heads, I’ve had a few conversations with Tony over the last couple of weeks.
Happy New Year to all!
ID:	307831   Click image for larger version
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #572
Old 12-31-2012, 07:38 PM
GTOGEORGE's Avatar
When you are doing a Boosted Engine you don't need a Boosted Engineer just the Internet and some "common sense"! Of course any help is better then no help.
GTO George
  #573
Old 12-31-2012, 07:44 PM
Elarson's Avatar
Bypassing the internet advice and middlemen; and going directly to Tony sounds like the right approach. Good luck for 2013!
Eric
  #574
Old 12-31-2012, 09:19 PM
GTO George
Nice thing about the internet, for some people, is they get to find people who agree with them on their theories, be they right or wrong.
Tom Vaught
  #575
Old 01-04-2013, 10:29 AM
twov8sandat4's Avatar
twov8sandat4 twov8sandat4 is offline
Do you expect to be at the track this year?
Hope you sort out all the problems.
Panos
Little Miss G Racing on Youtube
  #576
Old 01-04-2013, 06:00 PM
RAIV-Z's Avatar
That’s the current plan, although that assumes the engine can get sorted out to my satisfaction.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #577
Old 01-21-2013, 03:29 PM
RAIV-Z's Avatar
The cage is painted and back in the car.
ID:	310483   Click image for larger version
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #578
Old 01-21-2013, 07:24 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
looks good. but damn it looks hard to get in and out of it..
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #579
Old 01-21-2013, 08:02 PM
Bnick166's Avatar
Bnick166 Bnick166 is offline
Definately not for a full figured man!....Holy Jungle Jim, Batman!
  #580
Old 01-21-2013, 08:26 PM
That is going to be another one of those A$z entry first, deals where you put your legs inside the cage first, bend over, kiss your a$z, then sit down in the seat types of things. Good thing Drag Racing does not have a rule like the SCCA where you have to be able to exit the vehicle in so many seconds.
Tom Vaught
