#121
Old 12-22-2012, 01:15 PM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
GW...WOW looks fantastic!! Thanks for the tip on phosphate process, think I will try it for bolts. I have been putting them in a EvapoRust/SEM type solution and depending on how they look coming out, either use them after wiping down, or bead blast/wire wheel them and paint heads with flat black. Are you cleaning up the original fuel/break lines, or replacing them? Where did you get the red plugs to cap off the steering gear box? I have been looking for some but can't find them, unless I buy a new gear box. Thanks for the pics! Have you ever thought about writing a book/guide on auto restoration
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
  #122
Old 12-22-2012, 10:59 PM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
Charles,
I have new stainless fuel and brake lines from Inline Tube. The calipers are from them as well. I had originally got them from OPG but they had a metric banjo bolt and that was just not going to fly with me, call me weird.
The red caps on the steering gear where there when I got it back from being rebuilt. I took the original unit to a local shop that rebuilds for all the parts stores around. I asked them NOT to paint it as they spray everything and if I remember correctly they spray it all black. I left the aluminum raw and sprayed the cast unit with a cast grey paint.
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
  #123
Old 12-24-2012, 04:26 PM
Nicks67GTO Nicks67GTO is offline
Your garage is awesome.
  #124
Old 12-24-2012, 09:18 PM
69Customs's Avatar
69Customs 69Customs is offline
Those wheels look great!!
You said you matched up the paint to your spare. Do you mind sharing the paint code numbers so I can have my paint shop give me the same mix?
I also just masked off my wheels and cut the tape with a razor blade. Wasn't that much time and came out better than the masking kit they sell.
Old 12-25-2012, 10:01 AM
70UglyBird 70UglyBird is offline
What amazing work on that car. Subscribing. Hope to see this thing rolling around the "wood"!
1973 Firebird, Formula hood, 466 roller cam, ported heads, T56, Hotchkis springs, Koni shocks, DSE Subframe connecters, PTFB upper a arms, re-enforced lowers with global west delrim bushings, C5 brakes front and rear, 18 inch Boss 338 wheels, 4th gen TA power seats seats, Morris seatbelts, hydrotech hydroboost, speed hut gauges
1973 Formula 4spd long term project
  #126
Old 12-25-2012, 05:14 PM
GOAT WHORE's Avatar
These are Sherwinn williams paints. WOW look at the date, 2007 this car is a loooooong term project.
Ya, one day but its going to be awhile. I drive my 70 all the time in the sunny month or months if we are lucky
Do you drive that 73 much, ive never seen it.
  #127
Old 12-25-2012, 05:46 PM
No not yet. Although this summer should be the summer. Assuming the 466 is running like it should and the brakes work I plan on daily driving it as much as possible this summer. We'll see.
I think I saw your 70 once at the gas station but that is about it. And yes weather like this makes me think I should just give up the car hobby and buy an Accord I don't care about it. Rain gets old.
Merry Christmas!
  #128
Old 12-25-2012, 09:44 PM
goatman65's Avatar
redlines in the snow.
  #129
Old 12-27-2012, 04:13 PM
GW-
I'm guessing that you used a spray gun and not spray bomb's on your wheels? I have a auto paint store close by, and have had them mix paint before and put it in spray cans. Not sure if you went that way or used a gun?
1976 Formula 350.
1968 Olds 442.
1971 TR6.
  #130
Old 12-27-2012, 06:11 PM
GOAT WHORE's Avatar
Originally Posted by charles bledsoe View Post
GW-
I use a spray gun.
At first I used some pre mixed quarts from OPG if I remember right. The one color was way off. When I called they said they were having issues with it. Pisses me off, all that work for nothing, had to re do them. It's better in the long run as I believe that stuff from them was no where near the quality I got from Sherwinn Williams.
Long story short the masking kits and paint you get from some of the Pontiac suppliers are garbage. JMO.
  #131
Old 12-27-2012, 09:37 PM
Guys, I painted a set for a car I owned a few years ago and used rattle can Dupli-Color right off the shelf at Wal-Mart. Masked with tape and cut with a razor. Two regrets....I never recorded what colors I was using and don't remember except that it was Argent and Charcoal. The other regret is that I did not paint the backsides.
I found out that the backsides DO show when mounted on the car.
Old 12-27-2012, 10:14 PM
GOAT WHORE's Avatar
Hey, do I see a truck in your garage
Wheel looks pretty darn good.
  #133
Old 12-28-2012, 12:57 AM
Yeah...'69 el Camino....also long gone...lol
Old 12-29-2012, 10:55 AM
69Customs's Avatar
Hey Thanks Goat Whore for the paint specs. There is so much controversy about what the original colors should be and every one has their opinion. I'll have to visit my Sherman Williams paint store and see if I can get some mixed up. Maybe they can put it in spray cans?
Thanks again.
Old 12-30-2012, 10:11 PM
GOAT WHORE's Avatar
Default Another great day in the shop
Mike worked on roughing out the fenders and I was test fitting trim.
Got these re-pop tail light bezals from Richard Sargent. They are VERY nice. I looked for some time to get a set nice enough to re-chrome, when I got these I gave up the search.
I took a set of lesser quality pieces of trim and cut the posts off, drilled thru that spot and it became my pattern.
  #136
Old 12-30-2012, 10:34 PM
GOAT WHORE's Avatar
Default 400 .030 over with 4.210 stroke = 455, NICE!!!!
I going to use the orginal block, heads, intake and carb. Will run RAIII Exhaust manifolds and a MSD ready to run with black cap.
Sent the heads and intake off to Dave bisschop @ SD Performance to get them ported to 260 cfm and rebuilt, intake port matched to RAIV. These things look awesome! They are set up to run his "Stump Puller" hydraulic roller. Pretty cool, Dave flows an intake port and sends a copy of the results.
Hopefully going to get the rotaiting assembly with forged crank and cam set up this summer.
  #137
Old 12-31-2012, 12:53 AM
The heads look Great .
What Comp.Ratio are you going to aim for ?
Was your tail light panel painted black or body color ?
  #138
Old 12-31-2012, 01:03 AM
GOAT WHORE's Avatar
I will need to run a dished piston and probibly shoot for around 9.5:1 but Dave at SD will have final say about that.
Here is a shot of the tail light panel before stripping.
  #139
Old 12-31-2012, 01:09 AM
You have a great fit on that trunk lid, aligns really nicely with the backs of the quarters and really nice up the sides too! That's always a tricky area to get nice, often the factory fit wasn't great (especially the left side at the rear). A little cheater touch is to ream out the taillight bolting holes a touch, the factory tail panels were off a touch and the taillights always slant a bit inwards.
Old 12-31-2012, 01:14 AM
GOAT WHORE's Avatar
North, that is too funny you mention that. Mike and I finished up the day by looking at the tail light bezels and he says "I will open up those holes a little to straighten up those bezels".
Thanks for all the nice comments guys.
