Old 05-21-2013, 03:30 PM
pggto's Avatar
pggto pggto is offline
Default Subframe Interchange
I have a 67 Firebird and was thinking of pulling the front end apart to detail the subframe and engine compartment. I was thinking of "maybe" getting another subframe and detailing that one and swapping it to cut down on the down time of the car. What subframes are interchangeable 67-69 Camaro and Firebird, are Nova subframes also the same? Thanks
Old 05-21-2013, 05:45 PM
silverbullet07 silverbullet07 is offline
They will all fit but none are the same. 67 has the bump stop on the frame, 68 is on the back control arm and 69 on the front.
They will all bolt up but don't be fooled there are differences between each year. I just went through the same issues trying to find the right frame and in good rust free condition. Decided on a reproduction 68.
Old 11-15-2013, 11:08 AM
ponjohn's Avatar
ponjohn ponjohn is offline
How was the fit and finish of the repop subframe?
Same thickness material?
Old 11-18-2013, 02:34 PM
1968firebird455 1968firebird455 is offline
Send a message via AIM to 1968firebird455
The repop frames are nice but pretty expensive. After seeing the price most people decide to restore their original or hunt down a cleaner one online.
Old 12-27-2013, 09:03 PM
mrgto69's Avatar
mrgto69 mrgto69 is offline
Pypes Staff - Tech
Default Repop sub frames
Hey Guys. Just purchased a 69 FB and it looks like I might need a sub frame. I'm toying with the idea of buying a repop sub frame. Have any 69 FB'ers installed this sub frame on their car? What are the problems..?
Old 12-27-2013, 09:35 PM
ponjohn's Avatar
Even on other forums I have not found any negative feedback with regards to fit. The only negative is the price.
I have found many OEM subframes for under 400 some bare, some complete.
Old 12-27-2013, 10:01 PM
I have a pretty descent 69 frame but you are about 6 hrs away. I purchased a 68 new aftermarket. The only issue I had was none of the holes that was suppose to be threaded was not. I had to tap several holes. The biggest issue with that was the sway bar mount to frame. The frame was not thick enough there to tap and it needed a rivet nut or a nut in the frame to support the bolts.
Nothing major but frustrating after spending that amount of money for it.
Old 12-28-2013, 06:20 AM
mrgto69's Avatar
Pypes Staff - Tech
my sub frame was hit on the drivers side and it looks like it's not square. I can have it straightened, then blasted and powder coated, but then thought it might be better to get a repop. I'm probably looking at more money this way.
Old 12-28-2013, 10:20 AM
Badss540's Avatar
Badss540 Badss540 is offline
Do yourself a favor and redo yours, it fits-no fabricating needed-and you'll save on not buying another one. I did mine, not hard just make sure you get it lined up right when you put it back in.
The Following User Says Thank You to Badss540 For This Useful Post:
