Old 12-27-2013, 10:01 PM
silverbullet07 silverbullet07 is offline
I have a pretty descent 69 frame but you are about 6 hrs away. I purchased a 68 new aftermarket. The only issue I had was none of the holes that was suppose to be threaded was not. I had to tap several holes. The biggest issue with that was the sway bar mount to frame. The frame was not thick enough there to tap and it needed a rivet nut or a nut in the frame to support the bolts.
Nothing major but frustrating after spending that amount of money for it.
