Old 11-30-2013, 07:17 PM
Dave M's Avatar
Dave M Dave M is offline
Default Hood Hinge Restoration
Does anyone out there have a good source for Hood Hinge restoration? The ones on my 71 Formula are a bit whipped.
Dave
Old 11-30-2013, 07:27 PM
70RAlll 70RAlll is offline
There is not much restoration besides blasting and having manganese phosphate plated( black phosphate). But if the springs are shot you can buy replacement springs.
Old 11-30-2013, 10:01 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
If your old hinges are sloppy and the rivets worn, these guys will restore your hinges including drilling out all the rivets and machine new correct rivets. They also blast and will optionally powder coat if you prefer. They did my '72 hinges and a number of other PY members as well: http://www.hoodhingerepair.com/
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
Old 11-30-2013, 10:35 PM
Norwood's Avatar
Norwood Norwood is offline
Do they Properly plate as an option or just powder?
Old 11-30-2013, 10:42 PM
RicksGTO's Avatar
I don't think they will plate them but it's been a few years since I used them so can't say for sure.
Old 11-30-2013, 11:04 PM
Dave M's Avatar
Thanks for the good info guys. I'll check with them on Monday. I'd like to get the rivets replaced and have them plated if they do that. If not, I guess powdercoating would be OK.
Old 12-01-2013, 12:46 AM
Norwood's Avatar
Not on a correct restoration...I'm currently working on this, but in the meantime you should google Roland Hall hood hinge
The Following User Says Thank You to Norwood For This Useful Post:
Old 12-01-2013, 10:09 AM
RicksGTO's Avatar
here is the info on the guy Craig is referring to:
Rowland Hall, 1901 Jackson St, Burbank, CA 91504, 818-845-3574
Old 12-02-2013, 04:12 AM
If you want the phosphate plating to look and last like OEM GM did, Paramount Metal Finishing in New Jersey is my favorite place. I have found the commercial plating shops compared to the do it yourself kits is just no comparison. You will end up with same quality GM currently gets. Look them up on yahoo, you will see they do it all, GM,Ford and Chrysler spec'd plating, military contract platings.The entire gambit. Just get a better finish. Plus sending your original, they can confirm what was originally used.FWIW< they confirmed my hood release latch and these hinges were originally manganese phosphate plated.
Old 12-02-2013, 08:03 AM
My442 My442 is offline
SMS in New Hampshire rebuilds hood hinges, and re-phosphates them too.
Old 12-02-2013, 10:40 AM
superdutybob's Avatar
superdutybob superdutybob is offline
Thumbs up
Roland Hall is the man. He adds a very thin stainless shim between the sliding halves and the hinges work fantastic. Correct plating as well. All rivets are hand made to fit repaired holes and stamped to the correct appearance.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
Old 12-03-2013, 01:23 AM
Formulabruce's Avatar
Here is the thread on Roland's operation..
http://forums.maxperformanceinc.com/...d.php?t=720859
" Long may we DRIVE !"
Old 12-03-2013, 01:24 AM
Mopar guys I thought??
Old 12-03-2013, 08:04 PM
CAM400455 CAM400455 is offline
I had Roland Hall go through my hood hinges and they work awesome! The hood closes well, and has the correct phosphate color.
