Run at track shows 1030 HP (DA = - 1325 feet) Got it. Stan
The DA was no where near -1325'. Real racers work on there cars after they get it on the car.
Lil,
Let's compare HP/cu.in. My 511" motor with run-of-the-mill wideports, 1.6 rockers on 110 fuel made 920 HP. That's 1.80 HP/cu.in. Your 541" motor with Gaby heads, 1.8+ rockers and I'm guessing at least C16 or Q16 fuel made 965 HP. That's 1.78 HP/cu. in. So tell me again how I can't make power? And how am I a "hater" for recounting my experience? It appears the CV-1 crowd has taken the high road here, while the usual loud mouths spew their BS. According to your comrade Gach, even if my car goes faster with CV-1 heads, it still doesn't prove anything. So if head flow is meaningless, dyno results are meaningless and ET doesn't prove anything, what else is there? Dick Fulton P.S. I LOVE lining up next to a guy like you who runs his mouth. Lock it in, sucka !! |
Called out and bitch slapped, hahaha |
Oh don't worry it's locked it. The only thing that really matters is the ET slip, the rest I could care less. And don't you have a sheet metal and two dominators to make that 920 HP? Last edited by LiL Jack; 03-11-2014 at 08:33 AM. |
I heard you use Gray Goose!
Sorry but i don't think you do. There are several factors that effect the cars performance, more than just da. 3% is as close as you'll see car/dyno/a year of tuning, heck radials effect it.
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
There are items which effect et / mph like DA which also reflect a change in HP. There are other items which effect et / mph like traction which reflect NO change in HP. Stan
Thanks for the info Jim! That was good stuff.
My question for those who know is: is the 300rpm per sec Or the 600rpm per sec and predetermined setting on every dyno and when the motor accelerates that's when the force put on the brake is measured(torque) OR is it the brake is set at Whatever amount of resistance and the torque the engine puts out determines xxxrpm per second???? If that made any sense....is that a valid question?
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz “It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life” Notre Dame Head Coach Marcus Freeman 69 GTO NHRA Super Street Car 2860lbs 1/8 [email protected] 1/4 [email protected] in St.Louis April 2026 |
From Larry Meaux's forum:
Are you being serious? You cant really think i don't know about da. In a car spinning, it will show less hp due to less et and mph.
![]() Stan
Dick, What fuel do you use when you spray your car?
Hi Jack, We run two separate fuel systems in the car. We run 110 in the main fuel cell for the motor. 110 is available at the pump at several local gas stations that cater to the circle track guys. Also most race tracks we go to sell 110 on site. So it's nice to have a motor that is happy on 110. The smaller fuel cell on the left is for the nitrous system. We use C16 for that. So depending on how often we get out, a five gallon can of C16 can last a whole season. Have had no detonation issues with this set-up. The rod bearings looked so nice after the first season, we put them back in for the second season. Seems to be working okay. Dick |
