Old 03-10-2014, 10:10 PM
69FIREBIRD76MM's Avatar
[QUOTE=p4msi1;5153498]Know your competition
Butch Kemp
Smoked Another SBC
Posts: 5,225 1200hp SB2 thread,..............
Well, actually it came a tad short...but 1180hp from 419" isn't all that bad.
John Husek finished up his latest project a little while ago and finally got the time to put it on Extreme's dyno last saturday.
He then called Frank Iacionio for a quick appointment this last monday to verify the power it made.
Johns plans for this project were to work with myself to continue to make gains in the engine room as well as the race track, I guess i threw in the towel a bit too soon.
Anyway, this engine made 1180hp @9500 and 660 tq.
Sheetmetal intake and 2 "small" dominators, Johns carbs off his 1100hp 399" engine.
It was run on Q16 and with the same headers they dyno'd my 440 with.
Some people might not believe the #s, but I just wanted to put this post up as I believe it has to be the most powerful NA small block in existence!!!!
The head castings are GM SB2.2 castings with no major mods
Iron eagle 9" deck block
I believe Hughes did the manifold, John will have to verify..
John did the carbs as stated earlier
Jesel valvetrain components.
Killer job JTS,.......now work on your camera skills!![/QUOTE
My buddy is putting together SBF___400+ windsor. 1100+hp
Old 03-10-2014, 10:40 PM
bad69bird's Avatar
bad69bird bad69bird is offline
Dyno corrected HP = 998
Run at track shows 1030 HP (DA = - 1325 feet)
Got it.
Stan
Originally Posted by LiL Jack View Post
The DA was no where near -1325'. Real racers work on there cars after they get it on the car.
Couple of points to make...
1. When we dyno'd Jeff's motor at Philadelphia Racing Engines is was raining and the owner (can't remember his name) said that his dyno was stingy. So the conditions were not even close to optimum.
2. Jack is correct. Even after the motor was dyno'd we continued to refine the set-up just about every pass to get everything out of that motor/chassis we could! That car was a continuing work in progress. We always strived for more!
3. When he went 8.42 the DA that day was not even close to mine shaft air. If my memory serves me correctly (Jeff correct me if I'm wrong), I believe the air was 600-800 feet and the barometer SUCKED. Jeff's car is so efficient...but there is always room for improvement.
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs)
Old 03-10-2014, 11:07 PM
john marcella john marcella is offline
Lots of but,but,but ...."BUT" still no sheet! Granted some of it is valid points.
As far as Im concerned Jeff makes a 1000 no problem 998 on a rain day, yup. Ran better in the car to at hut-hum cough cough 600-800 ft
I was E mailed one but it would not open the PDF. Supposed to be 1021 hp E head sheet!
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
Old 03-10-2014, 11:20 PM
My point to this thread is that it seems that its presented as if there are lots of 1000 hp E headed motors out there, seems now that the truth is....there's just not!
I was only thinking of this because Mike L. is trying to break through this barrier as He and I are working on his stuff now. I thought to myself, ya know I have never seen a 1000 hp e head dyno sheet but I hear of it all the time.
That's why the post.
John Marcella
[email protected]
ph. 248-259-6696
Old 03-18-2014, 10:17 AM
Chris , this was post #90.
You don't know this but there is a few here that like to use 1000 hp H head as a stick to beat on other cyl head camps and the 1000 hp E head gets referenced a lot and is made to seem that there is many, at least that's how I take it
The funny part is those people cant produce a sheet that has 1000 anywhere on it.
I wanted to see for real how many have truly made over 1000 hp with E heads.
John Marcella
[email protected]
ph. 248-259-6696
Old 03-11-2014, 10:55 AM
Stan Weiss's Avatar
Originally Posted by mike leech View Post
Not really he made 998 on pump. showed 1030 in car. makes sense
Brian,
My reply was based on the quote above from Mike.
Tuning and increasing HP after dyno testing does happen. But if the motor was re-dynoed it would produce higher HP.
Stan
Pontiac Pump Gas List
