Old 09-12-2014, 07:24 AM
Look at post #12 and #14.
EDIT: Sorry, I was showing frustrations again, my bad.
Old 09-14-2014, 12:54 PM
F ROCK's Avatar
F ROCK F ROCK is offline
it's all good, I was showing mine too.
i'm glad you've responded to help me.
thanks again everyone.
Old 09-14-2014, 01:15 PM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
The bearing is a timkin part #1377C
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
Old 09-14-2014, 04:33 PM
F ROCK's Avatar
thanks Dave, I've ordered one!
Old 09-16-2014, 10:08 PM
F ROCK's Avatar
ok. the bearing is in, trans installed, and the clutch is disengaging now. awesome.
still seems like I could've used an even bigger bearing tho, because my shaft is adjusted almost fully out, and the fork is about 1/8th inch from bottoming on the bellhousing again.
do I need a different brake pedal pushrod? I used the one from the automatic setup, but the pedal seems real low. lower than it was.
still have to find a drive shaft, I have the yoke tho.
does anyone know exactly how long the driveshaft would be for a 71 GTO w/ Muncie.
Old 09-17-2014, 06:59 PM
Make sure you are in the correct hole.
The 4 speed pedal and auto pedal will have two holes. One for manual brakes and one for power brakes. If it is too low, you might need to go to the upper hole in the pedal.
Dave
The Burb Files
