I fought this for months! My wife's left leg was definitely getting a work out!
I fought the entire system and ended up getting the adjustable ball stud and a new TO bearing!!! Using the TO bearing that you have with a non adjustable ball studd the clutch would never disengage... Here is a picture of the stuff you have with the rod adjusted all of the way out.. ![]() Differences in ball height.. ![]() TO bearing heights.. ![]() Highest ball height installed..
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files Last edited by 1967Tempest; 09-12-2014 at 10:16 AM. |
That throw out bearing in the middle of that pic is one of the type that is used with flat tine/finger pressure plates. The one to the left is generally used for borg & beck style.
When a ball stud is too long, you can 'over-throw' a clutch, and go past center, which can make it hang. .
Very true as it happened when I had the ball stud maxxed out. I settled on a nice mid point on the ball stud and the center TO bearing. This what I used when I put the Saginaw 4 speed in the car. Which worked perfectly when I replaced it with a TKO500. Consequently, I used the exact same set-up when I swapped the 67 Tempest Wagon over to a 4 speed. I used the same parts etc.. and it worked on the first try. My wife was relieved as she only pushed the pedal like 5 times and it was set.
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
Somewhere in the archives here are my struggles with this as well.
Toss is an aftermarket part, and the geometry went wacky. I used these for the push rods...they worked wonders. http://www.speeddirect.com/index.php...ucts/rod-links
........I'm just learning as I go....... |
