#41
Tom Syron |
#42
IMO. Any of the cookie cutter CNC versions from various vendors would get you into the 850-950hp range. Beyond that it will probably narrow the field down and drive the price up.
Tom Syron |
#44
5.40@129 w only a 1.28 60
2900lbs Like I said. Power is there. Everything else with the combo is a bit off.
68 Firebird "Indian Giver" 540 MR1, HP's, Wenzler -- For Sale $12,500 rolling Best of 5.12@134 on 175 shot 72 LeMans "POS" - Next US beast
#45
I've got a set of Dan's worked over HPs to go on the 500 if the E heads on it don't get me the et I want. He freshened and twesked the KRE hand ported E heads that are on it.
Saw Slowbird's stuff when I have been there before too. A few other guys from here's stuff also over the years. He did my 409 heads also.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
#46
You run the 1/4?
#47
Agreed. So have you been on their pump to compare?
#48
^^^^ This in spades, well done Tom^^^^
#49
Some facts for you,
Car #1 dynos around 1030hp runs 5.4@129 weighs 2900lbs, has ladder bars, tunnel ram and 2 carbs Car #2 dynos around 1030hp runs 5.43@128 weighs 3300lbs, stock suspension, victor intake and 1 carb What conclusion do you draw? Can you show me a 1000+hp kre that shows it on the track? |
#50
These cars could be running 5.30 @ 130 or there abouts. Clearly the delta can be found in the chassis, tune etc. |
#51
#1 shows over 1000HP with the MPH. #2 shows over 1100HP with the MPH. (1040HP by ET) Quote:
![]() Flyin79bird's car shows 1015 HP with the MPH.
#52
Put the crack pipe down!
I know of a well sorted out car and it shows north of 60+ wrong to the good.
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
#53
#54
If both pick up 29mph (a reasonable gain), then car#1 shows 915hp and car #2 shows 1020hp. Here is another example paper says 1000hp, car runs 9.2s at 146-147 car weighs 3300lbs, thats not 1000hp. |
#55
With only 3 clean passes absolutely no tuning has been done to find any extra power.
Finding an inflated dyno is next on the list so he can be like everyone else. A piece of paper that shows huge numbers but can't be backed up. No one seems to question the dyno, just assume the car sucks. |
#56
![]() Quote:
![]() Quote:
No it's not. Who's car is that? Probably needs to check the car out and find what is not optimized for that combo?
#57
Your car shows over 1040HP by the ET, the MPH shows you have more HP (1130 HP), so your car is needing some work to get it to ET better. What's wrong with the dyno numbers compared to the track results?
#58
BTW, are these naturally aspirated runs?
#59
You think 1100hp can be achieved with 511ci, HP heads and a Victor intake? If so all the more reason to call up Dan Barton is it not?
So car #2 has issues and car #1 is good? KRE dyno isnt being questioned but dyno #2 is? Yes #2 is a NA run and had a 1.26 60ft. |
#60
You brought up the "#2" .
The data for the #1 shows what he said. The MPH HP shows what the dyno said, the ET is off because he hasn't got the car lined out. ![]() Yours is basically the same setup. (if the numbers/data is correct) Your dyno showed 1030 HP? The car shows 1040 HP by the ET. But the MPH shows more HP than the dyno. So either your dyno is off or your data is off.
