I came pretty close to swapping out my 3.08's to 3.42's ..but after a few long highway cruises..decided not too..my current transmission is starting to show a little too much silver in the fluid..so I have a 2.75 low gear th350 coming from Hughes maybe a good alternative for a few.I'm hoping with that and a few other minor changes my car will get into the low 11.2's this year with a highway friendly 3.08!
And how much will the total build of the trans cost? Is the spread worth spending a touch more for an OD? Think it was Car Craft that did a 'Junkyard Builder' series and installed a 4L80E, got the trans for next to nothing, was only the peripherals they mentioned was an 'associated cost'. Interesting read, can Google it. If you're at a point and need to replace or rebuild a trans, that makes the choice much easier. .
Karl
As I mentioned, you approach the project as you do any other that is over X dollars, you can handle the peripherals the same, by saving and purchasing in stages. Plan it out. Live with whatever you have now and go for the big picture maybe is a way to look at it. In the long run, you spend less if you properly plan. .
