Old 10-16-2017, 12:36 AM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
Originally Posted by Rocky Rotella View Post
• “O” denotes Grand Prix’s 400 4bbl and base 428 4bbl specific 670 assembly.
• “(blank)” denotes 9787603-specific 670 assembly for AUTO trans GTO and Firebird 400s and 428 H.O.
• “Z” denotes 9787608-specific 670 assembly for MANUAL trans GTO and Firebird 400 and 428 H.O.
• “X” denotes the Ram Air-specific 670 assembly for the 400 Ram Air option in GTO and Firebird.
This is simply my best guess at this point. I cannot claim any accuracy just yet!
Thoughts?
Rocky,
Just to add in another bit of possible confusion, I have a base YH 428 out of a 67 Grand Prix that appears to me to be blank (no stampings). I double checked again today just to be sure, and I can't find any stampings. The heads do have some rust on them, but after wire brushing the area, I cannot see any remnants of a stamping on either head. So...
To the best of my knowledge, this engine has not been apart since it left the factory 50 years ago. From what I understand (from a fellow PY'er I bought it from), it was pirated from a 67 GP back around 1971 following an accident that destroyed the car. After that, it sat in two different garages for 40 years untouched before I bought it and installed it in my wagon. It still has not been apart.
So if its history is accurate, mine in a base 428 out of an automatic GP, yet it has no stampings (blank).
Hmmm...
Eric Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
Deuteronomy 8:3
Old 10-16-2017, 04:09 PM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
Originally Posted by Mister Pontiac View Post
Rocky,
Hmmm...
Thank you for the info!
So the question now remains, was "unstamped" used to denote the GP's 400 and base 428 4bbl cylinder head assembly up to a certain point? And was the "O" assembly that may have been dedicated toward GTO and Firebird 400 automatic applications eventually used on the on the GP's 400 and 428 4bbl, effectively eliminating the need for the "O" stamped casting entirely?
Old 10-16-2017, 10:28 PM
Great point, Rocky.
That theory would align with my engine (w/o stampings). It is indeed a late 67 build. F227 on the intake, although I haven't had the valve covers off since I installed it. Can't verify their date(s) at the moment, but I can safely assume they are close.
Eric Mitten
Deuteronomy 8:3
Old 10-16-2017, 10:41 PM
Ram4king's Avatar
Ram4king Ram4king is offline
Ever see a set like this?
Old 10-17-2017, 11:48 AM
GRX's Avatar
GRX GRX is offline
Yes. Have a pair on my shelf. Seems the '061' numbers have two configurations.
>> http://forums.maxperformanceinc.com/...d.php?t=503112
ID:	465578   Click image for larger version
Old 10-17-2017, 12:32 PM
Thanks for the photos!
That's correct. I've seen them both ways.
Old 10-18-2017, 01:23 AM
ck67goat ck67goat is offline
Rocky,
Hmmm...
I've seen blanks like those almost 30 years ago at a car show. I believe a full size 67. To my recollection, the owner said they were service replacement heads. I could also swear I heard somewhere it was not uncommon for the 670s to be replaced by the dealer, can't remember why or where. Oddly, I have a 67 YK block from the original owner and the 670s were dealer replaced by 62s that were cast in the early 70's, so maybe they either stopped casting or never did cast service replacement 670 heads for some reason. I'm going out on a limb to guess maybe it's because the chamber design was no longer being cast. Would be interesting to know which chamber design your heads have.
67 GTO street car - 428, roller cam, TH400, GV OD, through mufflers Best ET - 11.44. Best MPH - 116
67 GP Convert 428 HO Project Car in process
67 GP Convert 400 (not sure yet if parts car or future project
68 Catalina Convert 400 - all original 135k miles
